JavaScript Maps SDK Blog
253
1.1M
90
| Open | I have found discussion on this topic in couple of other threads (Permanently change the order in layer list widget ,... by fdeters Frequent Contributor 0 0 | 0 | 0 | |
| Open | Pretty simple idea. Allow the JS SDK be able to take advantage of network topology.It was to my utter surprise that I... by COSPNWGuy Frequent Contributor 8 6 | 8 | 6 | |
| Open | When drawing a shape using the sketch component, the lines are labelled with their length. However, once the shape ha... by EricNagel Emerging Contributor 2 1 | 2 | 1 | |
| Under Consideration | With the Search component, I want the option to hide the "Search in" sources dropdown menu when the component has mul... by fdeters Frequent Contributor 4 3 | 4 | 3 | |
| Open | Hello Esri team,First of all, thank you for the great work on the ArcGIS Maps SDK for JavaScript. I use it a lot and ... by DaoYu Occasional Contributor 2 1 | 2 | 1 | |
| Open | We would like the out-of-the-box Sketch component in the ArcGIS JS API to have to ability to draw and edit polylines,... by GILBERTNG1 Occasional Contributor 4 0 | 4 | 0 | |
| Open | When changing a subtype, for example the type of an object, ArcGIS Pro and the JavaScript SDK Editor widget request c... by FabianHannich Occasional Contributor 1 0 | 1 | 0 | |
| Open | This is a request to enhance the Directions widget to display all direction segments and network auxiliary properties... by DanaeeFelix1 Emerging Contributor 0 0 | 0 | 0 | |
| Open | Description:We use a feature service in our ArcGIS Enterprise Portal where a layer contains more than 100 subtypes. I... by FabianHannich Occasional Contributor 4 1 | 4 | 1 | |
| Open | I am a developer of GIS Web components, and I would greatly appreciate it if the logic that converts a MapView into a... by gqzomer Occasional Contributor 5 2 | 5 | 2 | |
| Under Consideration | I am a developer of GIS Webcomponents, and I would like support for printing of graphics that use symbology with prim... by gqzomer Occasional Contributor 4 1 | 4 | 1 | |
| Open | It seems to me that it would be useful if `parseWhereClause` from `@ArcGIS/core/core/sql.js` returned the actual pars... by DanRussell Occasional Contributor 1 0 | 1 | 0 | |
| Under Consideration | The Esri attribution at the bottom of the map should allow for custom styling. It is seemingly styled in the arcgis-m... by LMFGeospatial Occasional Contributor 2 1 | 2 | 1 | |
| Open | Hi Esri!I made a post in the sdk questions section and made a official ESRI support ticket with this question:https:/... by michaelpoa Regular Contributor 0 0 | 0 | 0 | |
| Already Offered | Currently it is difficult to generate a custom implementation of a legend for a map layer without relying directly on... by JonathanDawe_BAS Frequent Contributor 0 4 | 0 | 4 |
Idea Submission Guidelines
