Power BI ArcGIS connector fails to display basemap imagery from our Enterprise Portal
1383
14
03-20-2025 12:39 PM
nick_red
Issue Details:
  • When opening Power BI, a login prompt appears for ArcGIS Online (AGOL). We hit cancel, then proceed to log into our Enterprise Portal through the ArcGIS connector widget.
  • Previously, we were able to select and display our custom basemap imagery without issues.
  • Now the basemap imagery no longer displays for most users.
  • The following error message appears in Power BI: "The basemap is unavailable or has been deleted from the server. Sign in from another visual then reset the map."
    On my computer, the basemap still displays correctly.
  • Most other users encounter the error.
  • When I try opening Power BI in a private browser window or in Power BI Desktop, I also get the error.
  • No changes have been made to the basemap in the past week.
  • User permissions do not appear to be the issue since I also receive the error in private browsing mode.
  • Basemap does not pass the embeded/publish check
NaZhang_Esri
Hi @nick_red
Thanks for trying it. The validation check is for both embed and publish, so that might be confusing since sometimes it passes the embed but failed publish. We will enhance the embed and publish check experience in the next release. Could you also please refer to this comment and see if it helps? https://community.esri.com/t5/arcgis-for-power-bi-questions/power-bi-arcgis-connector-fails-to-displ....
FMGLGIS
We are experiencing the same behavior, started occurring in recent months, previously org shared imagery services were displaying as expected in published dashboards. Replying to follow the thread, we're also logging a case with ESRI support.
NaZhang_Esri
Hi @FMGLGIS,
Thank you for letting us know! We're preparing a blog post with troubleshooting tips for basemap blocking page issues to help you better understand what's going on. Please stay tuned, and thank you so much for your patience.
FMGLGIS
Hi NaZhang, was there any update on this one? We're spending a lot of time trying to figure it out internally and with ESRI support and I'm sure others are too. Was there a root cause/PowerBI Addin application change you've been able to identify?
NaZhang_Esri
Hi @nick_red @FMGLGIS @Anna-K -
A blog has been published to help you troubleshoot the Basemap blocking page issue. Please check it out here:
ArcGIS for Power BI Basemap Blocked – Troubleshooting Tips
Thanks very much for your patience. 😊
