Congressional Redistricting
With the recent redistricting of Congressional Districts for the upcoming midterm elections, when can we expect those updated district boarders to be recognized on the ArcGIS for Power BI visual?
Exact Match fails for "MUSCAT" (Oman) at Provinces level — works with fuzzy match, fails 1-of-6 with Exact Match on
Hello I'm using the native Power BI map visual with Represent location as: Boundaries, Region = Oman, Geographic areas = Provinces, bound to a text column containing standardized wilayat names (AS SEEB, BAWSHAR, MUSCAT, MUTTRAH, QURAYYAT, AL AMRAT). With Exact match OFF: all 6 features match and render correctly ("Features…
Unable to Setup a Join Layer Using GlobalID Field
I'm building a Power BI dashboard that pulls in data from an Excel file where each record is identified by a field that contains a GlobalID string. If I pull the spreadsheet into ArcGIS Pro, I'm able to join data from a feature service layer with the spreadsheet using GlobalID as the common key. However, when I'm…
Filter for more than 250 records
I am building an interactive selection panel into a map containing commercial real estate inventory data. I need to be able to select 1) more than 250 records and have the data and charts re-adjust to the filtered data, and 2) need to be able to apply varying symbology by field (selecting a field by which to base symbology…
ArcGIS for Power BI - v 2026.2.992 - Change Log and Updates
Version 2026.2.992 Release Date:06/10/2026 New features: Advanced Symbology support ArcGIS for Power BI now includes powerful new rendering options to help visualize complex spatial data patterns: * Pie (Donut) chart: Represents categorical proportions at each location (e.g., breakdown of land cover types, or product…
Feature Information will not enable
Since update the feature information will not toggle on whether you use power bi desktop or power bi online. I sign in and use a public facing service or map and once I try and toggle on feature information it removes everything.
Maps broken / Proxy Failed to fetch
I use the ArcGis map for power BI to create map using the county geocoding of my country (France) My report has been working for years without issue Now all maps using the county geocoding refuse to load and I get the following error message : "unexpected error due to proxy server" (I translated it from French, not 100%…
Completely Broken: ArcGIS for Power BI unavailable, browser does not meet image processing reqs, WebGL-supported browser required
All of my desktop PowerBI dashboards are broken as of this afternoon. ArcGIS for PowerBI map is unavailable.
ArcGIS Online data layers not showing in Power BI unless ....
Hello, I am encountering the issue where I can add a ArcGIS Online data layer onto the map in Power BI desktop. I then save the report, close Power BI desktop. When I then open it again, the map shows up but no data layers showing. I have discovered that I need to add a semantic model (this is a small table with 2…
Lat/long search not working in arcgis power bi visual
Searching by latitude/longitude in the in-map Search tool stopped working. Typing coordinates into the search box returns no results. The map itself renders fine and our points plot correctly from the Latitude/Longitude field wells — it's specifically the lat/long search that's broken. We're using the visual as guest users…
Map lasso is not always working
We are experiencing an issue with the ArcGIS map visual in Power BI. Scenario: The report page is already filtered on a specific city (via a slicer). However, when using the lasso selection tool on the map, no data points are selected. The lasso tool only starts working after the user first clears the city filter in the…
Share a hosted feature layer on Power BI visual that implements Esri group permissions
Hi. We are ingesting data from multiple source systems into a Microsoft Fabric environment and create Power BI visuals based on that data, including inserting reference layers such as boundaries from our ArcGIS Enterprise. I work for African Parks Network, and as a conservation organization we are creating Power BI maps…
ArcGIS for Power BI - v 2026.1.970 - Change Log and Updates
Version 2026.1.970 Release Date:04/17/2026 New features: Measure Tool The ArcGIS for Power BI visual now includes the Measure tool within the Analysis pane, enabling users to calculate linear distances and polygon areas with perimeters. The updated interface supports dynamic map panning during active measurements, ensuring…
Using ArcGIS Data in Power BI Elements and Visualizations
Hello! So I think I am not fully understanding the point of ArcGIS for Power BI. I want to be able to use AGOL Data to create Power BI Visualizations and I am only finding documentation for using the ArcGIS for PowerBI visualization and adding layers and just having that map with layers, but nothing really about using agol…
altitude longitude latitude, pour il manque Z?
La cartographie est en 3D, pourquoi le champs altitude n'est-il pas pris en compte dans Power BI? Exemple traitement des données ADS-B avec Power BI avec plus le maximum de lignes à traiter ?
PBI Native Tooltip only appears when hovering over a point's center, but not near the outside
Hello, I am working with a map that contains point data, with symbol type = size. These points come from a data layer, so I am using the native PBI tooltip in my design. The problem is that the tooltip will only render when the cursor is directly at the center of the point. If the cursor is inside the point, but not at the…
More Tooltip Customization
Right now, it seems like tooltip customization in ArcGIS for PowerBI is limited to changing fonts and colors (see example below from ESRI documentation). It would be helpful to be able to format the tooltips like a table with borders between each row/column to better differentiate each data point, and more ways to…
ArcGIS for Power BI – click map feature to open another page?
Hi everyone, I’m exploring whether it is possible for end users to click on a point feature in an ArcGIS Maps for Power BI visual and have it redirect (or open) a Power BI report on another page within the same report. Ideally, this would behave like a drill-through or hyperlink action triggered directly from the map…
Does ArcGIS for Power BI have performance limitations when working with large polygon layers?
Hello, I would like to clarify a question regarding performance when using large polygon datasets in ArcGIS for Power BI. We are using the ArcGIS connector in Power BI to visualize geographic data composed of state and municipality boundaries, which results in a dataset with a relatively large number of polygons. During…
Avoid Broken Maps: Validating ArcGIS for Power BI Before Embed and Publish to Web
In the ArcGIS for Power BI version 2025.3, we’ve enhanced the entire Embed and Publish to web validation experience to make it more useful and reduce confusion. In this blog, we’ll cover the following topics: * What are Embed and Publish to web? * Understand embed and publish workflows with ArcGIS for Power BI * Complete…
Add support for group layers in ArcGIS for Power BI
With group layers being supported in ArcGIS online and not in AercGIS for PowerBI, we are facing issues when users try to add these layers to their PowerBI reports. It is not possible in PowerBI to search for the group layer, and one have to manually go into the group layer in ArcGIS Online and find the names of the…
Layers from Enterprise stopped loading in the published Power BI Report. (Local Network Access)
ArcGIS layers (retrieved from internal Enterprise portal) on their Power BI report stopped loading recently. It used to work well before. Looking at the network traffic, it gives CORS error. We confirmed all Power BI domains are added to the 'Allow origins' settings at the portal security level. This seems to be related to…
ArcGIS for Power BI visual ceased to load in Desktop and Server
Hi, Since this Monday, 26 January, I have been experiencing an issue with loading ArcGIS visual in desktop (v. May 2025) and server. The visual does not show up at all. It used to work beforehand without any problems. I cross-checked the settings: Configure ArcGIS for Power BI—ArcGIS for Power BI | Documentation and Create…
ArcGIS for Power BI - v 2025.3.950 - Change Log and Updates
New features: Sign In and Sign Out The ArcGIS for Power BI visual now includes dedicated Sign In and Sign Out controls in the Login | Settings area of the Profile pane. This gives you more direct control over your connection, making it easier to manage how you access your data. Having explicit control is particularly…
Keep having to sign in to ArcGIS in powerBi and republishing everyday
Hello, I keep having to sign in from powerBi desktop and publishing every day, and even more than once a day, otherwise the published report shows contact publisher image, the whole point is to have this map available to our users 24/7
