ArcGIS for Power BI
Browse ArcGIS for Power BI
Sort/Filter :
Latest Activity
Sort/Filter :
POST
Hi all,I’m working on a workflow where KPI data is visualised in ArcGIS Maps for Power BI. However, one key limitatio...
OriGudes230175
by OriGudes230175 Emerging Contributor
in ArcGIS for Power BI Questions Last Updated Wednesday
0 5
179
POST
Hi,I would like to change the projection for the basemap in ArcGIS for Power BI. Is there a work around for changing ...
CatherineDevitt
by CatherineDevitt Emerging Contributor
in ArcGIS for Power BI Questions Last Updated 2 weeks ago
0 1
POST
I created a Power BI report that contains several maps. This was published and initially was embedded successfully. T...
NancyMilholland1
by NancyMilholland1 New Contributor
in ArcGIS for Power BI Questions Last Updated 3 weeks ago
0 0
POST
Hello community,I am using ArcGIS for PowerBI version 2025.1.800I have a  ArcGIS map visual with the following setup:...
DanC5
by DanC5 New Contributor
0 1
POST
The drill through filters are applying to the visual but map does not autozoom when navigating from another page thro...
CaseyMarika
by CaseyMarika New Contributor
in ArcGIS for Power BI Questions Last Updated 08-20-2025
0 2
POST
Hello. I’m trying to search for a publicly available set of layers from the Government of Canada using the ArcGIS for...
STAW0657
by STAW0657 New Contributor
in ArcGIS for Power BI Questions Last Updated 08-15-2025
0 4
POST
I’m currently working with Power BI and actively using the ArcGIS integration. We have a need to visualize map layers...
TrondBrenden-Veisal
by TrondBrenden-Veisal New Contributor
0 2
POST
Hi! This issue is kind of hard to explain. I have several maps created in powerBI.  I have all of the advanced licens...
Hecht_Alice
by Hecht_Alice Emerging Contributor
0 5
260
POST
I'm trying to build a polygon map in Power BI using the built in ArcGIS visual. I have signed in to our ArcGIS server...
LCDataAnalytics
by LCDataAnalytics New Contributor
in ArcGIS for Power BI Questions Last Updated 08-02-2025
0 2
POST
Hello, Does ArcGIS Enterprise for Power BI work for those of us on Microsoft GCC? It seems that my organization have ...
AdrianSiew
by AdrianSiew New Contributor
in ArcGIS for Power BI Questions Last Updated 08-07-2025
0 1
IDEA
It would be really helpful if there was a way to update the map projection in ArcGIS for PowerBI. I have polar data w...
CatherineDevitt
in ArcGIS for Power BI Ideas Last Updated 2 weeks ago
0 3
POST
 Hi everyone, A blog has been published to help you troubleshoot the Basemap blocking page issue we've seen frequentl...
NaZhang_Esri
by NaZhang_Esri Esri Contributor Esri Contributor
in ArcGIS for Power BI Questions Last Updated 07-21-2025
0 0
BLOG
ArcGIS for Power BI version 2025.1.800 The basemap blocking page appearsIf the basemap used in the visual is deleted ...
NaZhang_Esri
in ArcGIS for Power BI Blog Last Updated 07-21-2025
1 0
POST
Greetings All - I'm using the ArcGIS map native to PowerBI desktop and trying to create a Buffer/Drive time analysis ...
tharpcoop01
by tharpcoop01 Emerging Contributor
in ArcGIS for Power BI Questions Last Updated 07-28-2025
0 2
POST
Hello there  I am working on a Power BI Report. I created a feature layer and am connecting it to the Power BI Datas...
Frostie10
by Frostie10 New Contributor
in ArcGIS for Power BI Questions Last Updated 07-17-2025
0 0
