ArcGIS for Power BI Questions
62
888.3K
266
Open | I would like the ability to hide latitude and longitude from the tooltip for the end-user experience. by Pyrostic New Contributor II 0 0 | 0 | 0 | |
Open | Popup prohibits my users from seeing what they are selecting using the polygon select toolOnce my users have selected... by EricTanderson New Contributor II 0 0 | 0 | 0 | |
Open | When filtering a single data point (Long, Lats) in Power bi, the Esri extension map zooms to close for the base maps ... by AlexL_QED New Contributor II 4 1 | 4 | 1 | |
Open | We need the Drivetime feature available for end-users to run on published Power BI reports using ArcGIS. The exact re... by VRamosUWH New Contributor II 1 0 | 1 | 0 | |
Open | Please add the ability for routing in the map to use a custom routing service published and registered with ArcGIS En... by EddieFung1 New Contributor II 0 1 | 0 | 1 | |
Open | Please add the ability for search in the map to use a custom geocode service registered in ArcGIS Enterprise Portal i... by EddieFung1 New Contributor II 2 0 | 2 | 0 | |
Needs Clarification | I also submitted this point on ESRI Ideas Submission community. the Point is that ArcMap is not that much flexible wi... by MUHAMMADAkhtarFaqir New Contributor II 0 2 | 0 | 2 | |
Open | It would be great if we could hide sensitive data in Power BI like addresses and coordinates. Due to concern of pote... by LisaDygert Occasional Contributor 0 0 | 0 | 0 | |
Needs Clarification | Hello. I was really glad and impressed when I found the ESRI visual in PowerBI. However, the largest limitations of ... by LeonidFradkin New Contributor II 0 1 | 0 | 1 | |
Needs Clarification | We have a reference layer in ArcGis online with polygons. In a seperate file we have a registration of plants and ani... by JeroenGroothuismink New Contributor II 0 4 | 0 | 4 |
Idea Submission Guidelines
