Hi @nick_red,
I'm guessing the credentials are cleared out for some users and also in a private browser. Could you please try to sign in to your portal first and view the report? Please let me know if this doesn't work. Thank you!
Hello NaZhang_Esri,
Yes, I tried that, and it didn't work. I found the issue causing my problem after working with an ESRI representative. The issue was that after setting the imagery layer and the web map the imagery layer was linked to create our custom basemap to public, then validating it in PowerBI, the validation passes for the basemap with all green checks, and then I save it. When I try to view the map, it works. Even once I set the imagery layer and web map back to the sharing status of 'Organization' in Portal, it works. But this is not a good solution because: A) Our items in the portal can't be shared with the public. I can't set those two items to public, then save it in PowerBI and set it back to 'Organization' every time someone creates a new PowerBI report that wants to use our custom basemap imagery as the basemap.
This used to work just fine about three months ago when our items were set to 'Organization'. Please advise, ESRI was able to replicate this error too.
Nick
Thank you @nick_red! The representative has reached out to me and we are working to figure out what's happening.
Hello! Since we're facing a similar problem, I'll keep an eye on this thread for updates.
Did you try to sign in Enterprise in the Edit mode in Power BI and then go back to the map with the blocking page?
Tried it and still get that error. Feature layers display fine when they are shared with org (even though they don't pass validation) and you use the standard esri basemap. But if you try to use a custom basemap you will get this image after saving.
We are experiencing the same behavior, started occurring in recent months, previously org shared imagery services were displaying as expected in published dashboards. Replying to follow the thread, we're also logging a case with ESRI support.
Hi @FMGLGIS,
Thank you for letting us know! We're preparing a blog post with troubleshooting tips for basemap blocking page issues to help you better understand what's going on. Please stay tuned, and thank you so much for your patience.
Hi NaZhang, was there any update on this one? We're spending a lot of time trying to figure it out internally and with ESRI support and I'm sure others are too. Was there a root cause/PowerBI Addin application change you've been able to identify?
Hi @nick_red @FMGLGIS @Anna-K -
A blog has been published to help you troubleshoot the Basemap blocking page issue. Please check it out here:
Thanks very much for your patience. 😊
