ArcGIS API for JavaScript Blog
42886
33
Open | I think a property should be added to set the Search Widget or Layer Search Source to limit the search using the like... by DaveFullerton Occasional Contributor ArcGIS API for JavaScript Ideas Last Updated Friday 1 1 | 1 | 1 | |
Open | Include basemaps in the swipe tool - the most useful functionality of the swipe tool in the Flex web app was to be ab... by RebeccaWatson1 New Contributor III ArcGIS API for JavaScript Ideas Last Updated 02-01-2021 1 0 | 1 | 0 | |
Open | I would like to communicate an improvement for the FeatureTable widget in ArcGIS API for JavaScript 4.In the current ... by StefanUseldinger Occasional Contributor ArcGIS API for JavaScript Ideas Last Updated 01-21-2021 2 0 | 2 | 0 | |
Open | It would be great to have an option to generate a list and/or label line measurement segments when using the measurem... by MichaelSnook Occasional Contributor III ArcGIS API for JavaScript Ideas Last Updated 01-11-2021 0 0 | 0 | 0 | |
Under Consideration | The measurement Widget is great, but the point, line, and polygon symbols used by the Widget cannot be changed. In ma... by Lerman New Contributor II ArcGIS API for JavaScript Ideas Last Updated 2 weeks ago 1 4 | 1 | 4 | |
Under Consideration | The layerlist widget is great...however, when using it in mobile form and trying to scroll up or down through the lay... by MichaelSnook Occasional Contributor III ArcGIS API for JavaScript Ideas Last Updated 01-08-2021 1 1 | 1 | 1 | |
Open | We need a SymbolStyler in Javascript 4.x or a way to modify the layer symbology on-the-fly so that the layers can be ... by VivienWong New Contributor II ArcGIS API for JavaScript Ideas Last Updated 01-06-2021 1 3 | 1 | 3 | |
Open | add offline support for js api developers the same as the runtime edition. I want to be able to work with map when im... by GisNavy New Contributor II ArcGIS API for JavaScript Ideas Last Updated 01-06-2021 2 0 | 2 | 0 | |
Open | While in the process of upgrading an app from 4.13 to 4.17 JS API, we noticed that more animation/fade effects were a... by GILBERTNG1 New Contributor II ArcGIS API for JavaScript Ideas Last Updated 11-18-2020 4 0 | 4 | 0 | |
Open | In ArcGIS Pro and published through the feature service, support relationship tables in map tips via arcade expressio... by LukeSavage New Contributor III ArcGIS API for JavaScript Ideas Last Updated 10-08-2020 0 0 | 0 | 0 |
Idea Submission Guidelines
