Submit another survey in Survey123
4490
16
08-14-2018 11:08 AM
MarkLache1
Is there a way to allow a user to submit another response to a survey when developing with Survey123 Connect?
IsmaelChivite
Esri Notable Contributor
Hi Abigail Stephens‌. Yes. This has been resolved:
  1. Publish your survey with Connect
  2. Login to survey123.arcgis.com
  3. Open your survey in the designer
  4. Click on Settings
  5. Configure and activate the Thank You dialog.
  6. Publish from survey123.arcgis.com
BrandonArmstrong
Hi Mark,
Can you clarify where you are submitting responses? Are you submitting via the Survey123 field app or the web app?
MarkLache1
Created with Connect but using the web form for submission
BrandonArmstrong
It is not currently possible to limit/allow a second survey being sent via web app within the settings of Survey123 Connect.
Having said that, we do have an existing enhancement in our internal repo, which I will add your comments to.
Best,
Brandon
MarkLache1
So my only option is to recreate my survey in the web builder?
ClaireProctor
No, you can open a survey made in Survey123 Connect in the web app; there's a link provided when you sign in to the Survey123 website, that you can then distribute to whoever needs to fill it out.
Be aware that your survey won't look exactly the same, however, and depending on your survey not everything you need may be supported.
MarkLache1
But will this fix my initial problem?
deleted-user-c1vrBmSgUhGQ
Did you ever find out if this was possible in the connect app?
ClaireProctor
Hi Dawn,
It's not yet possible in Connect, but we hope to make it possible. Until then, the ability to prompt the user to send another response is only available in the web app.
MarkLache1
Hi Dawn,
No I have not found a workaround yet
Mark
