Scene Viewer Questions
97
314.5K
41
| POST | Hi,Prior to the recent October update I was able to upload a 3D tiles .3tz file to "My Content" and a service was aut... by Osurac38 New Contributor 0 2 | 0 | 2 | 284 | |
| POST | I configured a point layer's "Elevation" to using "Z-value" mode "Relative to ground". In editing mode, there's only ... by BrandonGuo Frequent Contributor 0 2 | 0 | 2 | 160 | |
| POST | I have a feature service do not have Z value, the "Relative to ground" option can link to an attribute. But after con... by BrandonGuo Frequent Contributor 0 0 | 0 | 0 | 148 | |
| POST | Hello, I've added point and polygon feature services into a scene and have been able to turn on and configure labels ... by Veronicampbell Frequent Contributor 0 3 | 0 | 3 | 318 | |
| POST | Hello Scene Viewer Users!Help us make Scene Viewer even better by taking our user survey . Whether you work in AEC,... by CliffSong 1 0 | 1 | 0 | 158 | |
| POST | I am using local projection in scene viewer; however I can't switch to basemaps with WMS link using same spatial refe... by BrandonGuo Frequent Contributor 0 2 | 0 | 2 | 248 | |
| POST | In the ArcGis PRO scene, we display pipes (e.g. fire rescue system), both horizontal and rising. For horizontal lines... by OndřejKaňa New Contributor 1 1 | 1 | 1 | 304 | |
| POST | Hello, The line layers I created in ArcGIS Pro, display an Unsupported CIM symbology on layer message when I add it t... by JGVadnais1 Regular Contributor 0 4 | 0 | 4 | 661 | |
| POST | Hi!I have a .las file which I uploaded from a local scene in ArcGIS Pro with "Share As Web Layer". When looking at th... by ErikAIversen Occasional Contributor 0 3 | 0 | 3 | 403 | |
| POST | Hello everyone,I've got a problem with the building level when upload .slpk to use building explorer in ArcGIS Scene ... by MCh Regular Contributor 0 2 | 0 | 2 | 415 | |
| POST | My organization's scene apps can not open on the AGOL some reason not even create new one. We don't know what's happe... by Bilguuntugs24 Emerging Contributor 0 2 | 0 | 2 | 433 | |
| POST | I thought that when I use to do an Elevation Profile, when I clicked on the Elevation Line, that represented the sele... by ScottJones1 Frequent Contributor 0 0 | 0 | 0 | 362 | |
| POST | Hello,My organization is looking at getting an aerial and LiDAR of our entire city and we'd like to display it in Ar... by RobynSnookCCB Regular Contributor 1 2 | 1 | 2 | 482 | |
| POST | So recently I've uploaded a 3D scene to AGOL that uses an extruded polygon layer, and it doesn't load in properly. It... by NicholasKurtz New Contributor 0 1 | 0 | 1 | 432 | |
| POST | I published a feature class from Pro that consists of completely vertical lines (created from 2 points with same xy c... by Jay_Gregory Frequent Contributor 0 1 | 0 | 1 | 573 |
