ArcGIS Workflow Manager Blog
102
21.1K
36
Open | We have a short workflow where all editors have the same privileges for productivity purposes. Once a job is assigne... by Ulises Occasional Contributor III 0 4 | 0 | 4 | |
Under Consideration | Holds in WMX should provide functionality to be release depending on time or an action. It will be useful to have a ... by Ulises Occasional Contributor III 0 5 | 0 | 5 | |
Open | When having multiple extended properties configured for a job type you should be able to control privileges for each ... by Ulises Occasional Contributor III 1 0 | 1 | 0 | |
Open | Currently, in ArcGIS Enterprise 11.1, there is no direct inbuilt step to display detailed output of standard (not cus... by MarkMindlin_idea New Contributor III 0 0 | 0 | 0 | |
Open | It would be useful from a UI perspective for those designing workflows to have the ability to group specific steps of... by Haley_Clowes New Contributor II 3 3 | 3 | 3 | |
Under Consideration | Using ArcGIS Workflow Manager Server 11.1, it is possible to create Extended Properties and define their default valu... by JohnAnderson1 New Contributor III 2 2 | 2 | 2 | |
Open | I could not find where this is possible, but it would be very convenient to be able to pull job extended properties (... by bbaker_tngeo New Contributor III 1 1 | 1 | 1 | |
Open | Defining a start and end date for a step would be something really helpful. Capability of setting a start and end da... by PabloRebufello New Contributor III 4 2 | 4 | 2 | |
Open | Hi,Requirement is to open map in ArcGIS Pro.We have 20 different maps and to open maps we have to create 20 different... by sirishb New Contributor III 4 1 | 4 | 1 | |
Closed | I realize this may come across as pedantry but I think names are important. According to the help, "Workflow items ar... by philippenn Occasional Contributor 0 2 | 0 | 2 | |
Implemented | Option to duplicate existing Saved Searches will be very much helpful. by Ranga_Tolapi Occasional Contributor III 0 8 | 0 | 8 | |
Under Consideration | Can you please add a 'Delete job' as a step type in Workflow Manager. This seems like it should be an option but it i... by JessePearson New Contributor III 0 4 | 0 | 4 | |
Open | In Workflow Manager Classic it would be good if there was no requirement to edit an extended property when running an... by MJames New Contributor III 0 0 | 0 | 0 | |
In Product Plan | It should be possible to add multiple related properties entries at a time using the edit extended properties step in... by MJames New Contributor III 1 1 | 1 | 1 | |
Already Offered | When using the ‘JTXDesktopSteps.LaunchArcMap‘ step type in ArcGIS Pro the only way to save any edits done to the open... by JHart New Contributor II 1 2 | 1 | 2 |
Idea Submission Guidelines
