Open | It would be helpful if Survey 123 had a follow me mode for delineating line and polygon geometries. We have a use-cas... by SWATConsultingInc Occasional Contributor 1 1 | 1 | 1 | |
Open | Trimble TerraFlex has nested feature collection, something that is very helpful during larger field programs.Nesting ... by SWATConsultingInc Occasional Contributor 0 0 | 0 | 0 | |
Open | A deleted survey cannot be restored on the tablet. Hence, the question arises whether it is possible to create a temp... by HannesVogel Frequent Contributor 3 0 | 3 | 0 | |
Open | When downloading mobile map packages created from WebMaps in ArcGIS Online > Settings > Manage Offline Areas, include... by LindsayRaabe_FPCWA ![]() 1 2 | 1 | 2 | |
Open | When users are filling out multiline text responses in the Survey123 field app, the text box grows in height with the... by Cara_Walter Emerging Contributor 1 0 | 1 | 0 | |
Open | Use of the parameter 'deviceID' in the Inbox Query Expression. In instances where:a survey is published for public u... by IanGallo Regular Contributor 0 0 | 0 | 0 | |
Open | Issue: If you quickly double-click a select_multiple question, any associated relevant calculations are ignored. Some... by abureaux ![]() 0 0 | 0 | 0 | |
Open | In modern coding frameworks, it is simple enough to allow the user (or the users system) to decide if the site or inf... by AshleyHannigan Emerging Contributor 5 1 | 5 | 1 | |
Open | I just realized, but "numbers" appearance fields don't respect "readonly".Here are two entry fields (both are type=in... by abureaux ![]() 1 0 | 1 | 0 | |
Open | My organization heavily utilizes the Survey123 field app for collecting data in the field. Sometimes users have to go... by MollyBurton Regular Contributor 0 0 | 0 | 0 | |
Open | Please add a simpler method for reordering photos in a multiline image question.In the Survey123 field app, users are... by MollyBurton Regular Contributor 1 0 | 1 | 0 | |
Open | It would be very helpful to have 0.5x zoom (i.e. zoom out/wide angle/etc.) for photo captures while using Survey123 f... by MollyBurton Regular Contributor 4 1 | 4 | 1 | |
Open | While Survey123 can extract EXIF data from a single image attachment to populate a geopoint, it does not appear to ha... by EuropaxEarth Regular Contributor 1 2 | 1 | 2 | |
Open | GNSS metadata reporting for geopoint question types is very built out, with the ability to access accuracy informatio... by mattkramer Frequent Contributor 1 0 | 1 | 0 | |
Open | We currently use the PortalURL AppConfig property in our MDM in attempt to guide our users to login via our Organizat... by rafgar Emerging Contributor 0 0 | 0 | 0 |
Idea Submission Guidelines
User | Count |
14 | |
6 | |
5 | |
5 | |
4 |
