MRF fails to import into mosaic datasets and to be read on image server
Hi, We are about to upgrade our image servers from 11.3 to 11.5. In that work we have detected, for us, a major problem. That upgrade involves involves upgrading ArcGIS Pro also. Our workflow is adding rasters to a mosaic dataset and then publish the mosaic datasets. What we have found is that we are not able to add MRF…
Incomplete OthoMosaic/DTM/DSM
ArcGIS Pro 3.7 Ortho mapping Wizard - I ran my drone data to day to create an Orthomosaic, DTM, and DSM. when they were complete some of the imagery was blacked out (on the higher elevation section) causing a hole in my three layers. I have run three other imagery sets through this same process and did not have these…
Missing Raster Error - After deleting source data for cached service
Hi everyone, I have multiple cached map services that are used to display imagery. They work great! Except I'm having one issue. So, each service was cached from imagery in a map, and after they were set up, all of the source data was removed from the server to save on storage space. The services perform great, very fast…
Raster Function Color Ramp with no Stretch
Goal: Be able to publish a referenced 1-band continuous raster to Image Server with symbology for a color ramp defined entirely on the source and maintain values for that raster in the resulting service. As described here:…
Raster Imagery Layer with Color Ramp on Image Server
What is the proper procedure for publishing a single band raster with values from about 0 to 700 as a referenced Imagery Layer on Image Server that has a default symbology of a color ramp for the raster values? The resulting Imagery Layer needs to: - Display with the color ramp symbology by default. - When added to Pro, in…
Manage Map Server Cache Tiles - Scale Order
Dear Esri, Can you edit the tool below so that the scales are listed in ascending order. One of the recent updates must of changed this, but ArcGIS Pro use to list scales in an ordered list from smallest to biggest. This was useful when creating cached services manually. Please see my screenshot for details. Thank you! Jon
I seek ariel-satellite photos for 1801 Milltown Road, Wilmington, DE 19808 from 1983, 1984 and 1985. Can someone help me with highRes photos?
Satellite photos from 1984 of local DE address requested
Publishing Image Service from Viewer Connection to Enterprise Database
I cannot publish an image service to my Enterprise Portal from a Viewer sde connection to my database. I can publish the same imagery from a Creator connection to the database. Is it just not possible to publish a mosaic dataset image service from a Viewer, or is there something wrong with my configuration? I'll provide as…
Modern workflow for multi-year imagery mosaics: ArcMap → ArcGIS Pro / Enterprise / Image Server?
Hi everyone, We have several years of imagery tiles that I used to process in ArcMap using the classic mosaic dataset workflow. It’s been a while since I’ve done this, and I’m looking to modernize the process using ArcGIS Pro and ArcGIS Enterprise (Portal + Server). We also have an Image Server license, and I’m wondering…
Default instance type for Image Server
For ArcGIS Server, installed as part of ArcGIS Enterprise, the default instance type is "Shared". When we installed all of our AGE components, we left the default settings in place. Today I noticed that our two image servers each hvae the default instance type set to "dedicated". Is "dedicated" the default for Image…
Programmatically Clipping and Resampling an Elevation Image Service using Arcpy
I am a GIS Data Analyst working for the Ontario provincial government and we have a series of public lidar elevation image services available here. I am working with an unrestricted version of one of our lidar image services in our Dev environment at a native resolution of approximately 0.5m resolution. Ultimately, I would…
Improve Error Handling and Logging for Image Server Raster Function Tool Availability in ArcGIS Enterprise 11.4
When attempting to access services on an ArcGIS Image Server in ArcGIS Enterprise 11.4, crashes can occur if the server's raster function file is not available. This issue is further complicated when the problem is due to a missing or moved file, which does not provide any clues in the GIS log, even debug log level, making…
Issue dedicating more hardware resources using image server raster analytics.
Hello ESRI Community, We've installed Image Server (10.9.1) with a raster analytics configuration on a Windows VM in Azure (24-core with GPU and 250 GB of RAM). The Image Server has been federated with Portal on another VM. It also has an Azure SQL enterprise geodatabase registered as a data store. Using ArcPro (2.9) we…
Overwrite Image Service With ArcGIS API For Python
I have an image service in 11.4 that I update twice a week. The source is a mosaic dataset in a registered geodatabase. I'm hoping to automate the publishing side of it, but can't seem to get anything to work using the ArcGIS API For Python. I found this article from 1 year ago which mentions you can't publish image…
How do we allow our users to upload imagery to an image service
Hi there, This article discusses the ability for users to upload their own imagery to an image service: https://enterprise.arcgis.com/en/server/latest/publish-services/windows/preparing-image-services.htm#ESRI_SECTION1_B8E8839107D04A7A97BA476C85464E84 However, I cannot find any instructions on how to enable this, either…
Implement an Image Layer View similar in concept to a Feature Layer View
Live imagery data is increasingly becoming a reality in the modern world. This is not just capture of EO data or drone data, but processed raster data and time-enabled data such as weather radar where update frequencies are decreasing to single digit numbers of minutes. To support maintaining this live data on a single…
Optimize Rasters - Creating Raster Proxies Question
When trying to create raster proxies I get this error, I am trying to create the raster proxy and store the proxy and cache in a blob container. First question for what I am trying to achieve is, am I able to create a raster proxy that lives on a local machine like my image server while the cache lives in a blob container?…
Missing parts of overview layers
My end goal is to have an image service that has downloadable tiles in our open data portal. This dataset will also serve as our imagery basemap. (Unless that's a bad idea to have the open data and the basemap from the same service. If so, let me know, please and I'll duplicate this or the service.) I haven't ever done…
Publishing Geoprocessing Tool as GP Service on Image Server
Hello Good People! I hope this message finds you well! I’ve been working on a custom tool that integrates deep learning models and utilizes image server capabilities in ArcGIS. My goal is to publish this custom geoprocessing (GP) tool to an Image Server. However, I’ve encountered some challenges and couldn’t find clear…
Tiled Imagery Layer not available in Portal after setting up image server
Dear community members: Our library is trying to build a new ArcGIS Server and Portal for ArcGIS. After our IT setting up the image server, I noticed that it did not have the Tiled Imagery Layer option to create imagery layers. It just jumps to the configure layer. I tried to create an imagery layer, and it seems that I…
Issues with raster dataset with different cell sizes in a time series in ArcGIS Image Server
Is it possible to display a collection of raster datasets with varying extents/cell sizes together in a time series using ESRI Image Server? Are there issues which could potentially occur when displaying multiple rasters with varying resolutions?
How to create contours from a DEM image service
Hello, We are publishing a bare earth DEM with a 1 metre pixel as an image service. Currently running ArcGIS Server 10.7.1. I want to automate the process to assist my users in creating contours from the DEM image service. The process would begin with the user selecting a polygon from our parcel map service and end with…
Issues with caching a Mosaic Dataset containing raster data from mulitple dates
Hi We have a large volume of Aerial photographs from over 20 years of data capture and have been using the process set out here to organise and publish them as a dynamic service but also caching the service to capture the imagery at the top of the mosaic…
Mosaic dataset has white space when zoomed in to certain levels
I have an image mosaic of ~150 TIF files and when I mosaic them it works fine. But when I turn on the mask - 255, 255, 255 to show as no color, i get these strange white lines appearing. This only appears when I am zoomed out, but as I zoom in it seems to disappear. When I identify these spots, they are truly 255,255,255.…
