Map Interaction Issue in Power BI After June 26, 2024 (Arcgis Online)
6525
20
06-27-2024 05:51 AM
AdebMoustafa
I created a map using ArcGIS Online, where I added layers, images, labels, and pop-ups. I imported this map into Power BI, and initially, everything worked perfectly. I could click on any point in the map and view the information and images I added in ArcGIS Online. However, on June 26, 2024, I encountered an issue: clicking on any point in the map no longer shows any response. It's now impossible to click on any point to view the information.
Your help is appreciated.
Thank you!
EmilyOlack
Hello, thank you for sharing that informational resource! My colleagues and I have run into a problem with the new Feature Information window. The Enable toggle for Feature Information will not stay toggled to "On" and simply reverts to "Off" immediately after clicking. Is this a known issue/bug, or do you have any recommendations on settings that need to be changed elsewhere? Thanks!
