Can you utilize the Emlid Flow app as a provider for offset data collection in Field Maps? If not is that option in the works?
No, I believe Field Maps only supports Bad Elf, Eos Positioning Systems and Spike for offset data capture in a third-party app:
There is an idea to support and some discussions on limitations / context that I'd recommend adding to here:
You could look to us ArcGIS Survey123:
https://blog.emlid.com/how-to-connect-reach-with-arcgis-survey123-a-step-by-step-guide/
It's possible to integration Field Maps and Survey123 for more complex data capture scenarios like this one.
Thanks Chris. I am in the process of communicating with Emlid to try and get this feature going.
