Offset Data Collection with Emlid
1046
04-03-2025 11:19 AM
WGIMaps
Can you utilize the Emlid Flow app as a provider for offset data collection in Field Maps? If not is that option in the works?
ChristopherCounsell
MVP Frequent Contributor
No, I believe Field Maps only supports Bad Elf, Eos Positioning Systems and Spike for offset data capture in a third-party app:
https://doc.arcgis.com/en/field-maps/ios/use-maps/configure-field-maps.htm#ESRI_SECTION1_4278F684691...
There is an idea to support and some discussions on limitations / context that I'd recommend adding to here:
https://community.esri.com/t5/arcgis-field-maps-ideas/offset-by-distance-direction-in-field-maps/idi...
You could look to us ArcGIS Survey123:
https://blog.emlid.com/how-to-connect-reach-with-arcgis-survey123-a-step-by-step-guide/
It's possible to integration Field Maps and Survey123 for more complex data capture scenarios like this one.
ChristopherCounsell
WGIMaps
Thanks Chris. I am in the process of communicating with Emlid to try and get this feature going.
