ArcGIS Experience Builder Ideas
Latest Activity (1562 Idea Submissions)
Sort/Filter :
Open
The ability to set/choose the reading order of screen readers (an accessibility tool) is currently available for PDF ...
AuroraB
by AuroraB Occasional Contributor
in ArcGIS Experience Builder Ideas Last Updated 3 weeks ago
13 1
13
Open
Hello all!In the mobile view of Experience Builder - even if you add features to fixed panels with the appropriate si...
SaraJL
by SaraJL Frequent Contributor
0 0
Open
The way that sidebar widgets open and close is inconsistent. Setting a message action on a Button to toggle the sideb...
MackenzeOriger
by MackenzeOriger Occasional Contributor
0 1
Open
It would be helpful if there was a simplified spatial selection or filter type widget in experience builder. Currentl...
hbontrager_dgco
by hbontrager_dgco Occasional Contributor
in ArcGIS Experience Builder Ideas Last Updated 4 weeks ago
6 0
6
Open
When building filter options within Experience Builder, I have found the need to be able to edit and create filters u...
PatrickBond4
by PatrickBond4 Emerging Contributor
2 1
Open
Allow for locally hosted apps that require SSO to load in Experience Builder via the Embed widget. This functionality...
ErinStepowski
by ErinStepowski Occasional Contributor
in ArcGIS Experience Builder Ideas Last Updated a month ago
41 1
41
Open
When an Experience Builder app is shared with multiple groups that have different access to layers in the same web ma...
AmrMortada
by AmrMortada Frequent Contributor
7 0
7
Open
Right now, I can turn off add and delete in the Edit widget settings for each layer in the map. This is great, howeve...
Teresa_Blader
by Teresa_Blader Frequent Contributor
in ArcGIS Experience Builder Ideas Last Updated 07-17-2026
1 0
Open
The Draw widget currently only shows measurements after you finish drawing a line, polygon, or circle, there is no wa...
MariusVerdes
by MariusVerdes Frequent Contributor
2 4
Open
Please add the viewshed widget on experience builder as existing on the instant apps 3D viewer. It’s a very useful to...
DimitriosPsaltis
by DimitriosPsaltis Emerging Contributor
in ArcGIS Experience Builder Ideas Last Updated 07-11-2026
3 0
Open
I love that I can set field and questions connections in Experience Builder with the Survey123 widget. This is awesom...
Teresa_Blader
in ArcGIS Experience Builder Ideas Last Updated 07-07-2026
2 1
Implemented
I love that a loading indicator was added in this latest update, but I don't think it's visible enough.Even just redu...
NicoleJohnson
by NicoleJohnson MVP MVP
2 6
Open
The Group Filter functionality has been a great addition to Experience Builder. However, there is one area where it s...
ZachBodenner
by ZachBodenner MVP Regular Contributor MVP Regular Contributor
in ArcGIS Experience Builder Ideas Last Updated 06-22-2026
5 0
Open
In Experience Builder in the edit tool configuration, you can set which fields are available for editing. You can als...
TD1
by TD1 Frequent Contributor
in ArcGIS Experience Builder Ideas Last Updated 06-19-2026
2 0
Open
The Experience Builder Add Data widget currently presents a service or item as a single selectable result. When an it...
KevinEscaleraRobles
by KevinEscaleraRobles Occasional Contributor
in ArcGIS Experience Builder Ideas Last Updated 06-16-2026
0 0
444 Subscribers
Idea Submission Guidelines
We love hearing from you about how to improve our products. To learn how to submit a valid idea, please review the Submission Guidelines
Suggest an idea
Top Kudoed Authors
