ArcGIS Experience Builder Blog
163
835.7K
31
Open | Hello, this is Joora from Esri Korea.The customer wants to remove "Add a Marker" fuction on pop-ups found on Web AppB... by JooraBaek New Contributor II 0 0 | 0 | 0 | |
Open | Using the Developer Edition here. On a nearly weekly basis, I am publishing an update to an Experience, and some of t... by jcarlson ![]() 2 2 | 2 | 2 | |
Open | Is it possible to look at expanding the default icons available for the Search widget? At the moment under general we... by Cory_Williams New Contributor II 0 0 | 0 | 0 | |
Open | For the Search Widget in Experience builder, there should be a way to disable that "fly around" animation when the u... by FredericPoliart_EsriAU New Contributor III 1 0 | 1 | 0 | |
Open | I would like to start an Experience Builder URL with a search string.example:https://localhost:3001/experience/2/?dat... by FredericPoliart_EsriAU New Contributor III 6 0 | 6 | 0 | |
Open | At the end of the Survey widget , once the user has clicked [Submit], the Experience builder should either close the ... by FredericPoliart_EsriAU New Contributor III 2 1 | 2 | 1 | |
Open | Please make the scale bar in Experience Builder adhere to the measurement units of the basemap.While Myanmar, Liberia... by CliveMultrim Occasional Contributor II 1 0 | 1 | 0 | |
Open | It would be really useful if users were able to re-order the position of layers in the Map Layer Widget, which in tur... by andrewdc_tt New Contributor II 8 1 | 8 | 1 | |
Open | Firstly, Experience Builder doesn't yet support having more that 1 layer list associated with a web map. It would be ... by David_Brooks ![]() 6 3 | 6 | 3 | |
Open | Add ability to use Arcade expression as a data source in ArcGIS Experience builder.So you can add charts from Survey1... by Kristen New Contributor II 3 0 | 3 | 0 |
Idea Submission Guidelines
User | Count |
10 | |
10 | |
7 | |
6 | |
6 |
