Datastore : "You don't have permission to perform this task"
2222
11
01-26-2021 04:15 AM
PierreLarondelle
New Contributor III
Hi, when I tried to perform any of the tasks regarding datastore config, I get this message.
I'm on windows server 2019, the cmd is from admin elevated prompt, all concerned folders have full rights.
Any ideas ? Thanks.
Tags (1)
JonEmch
Could you try running this prompt while logged into the windows service account that runs ArcGIS Datastore? It is a bit strange that running it as an admin results in a permission failure.
Please let me know if this changes the behavior.
Keep on keeping on!
PierreLarondelle
New Contributor III
Nope, even with domain account. I'm in touch with the IT to try a group Managed Service Account as described in documentation. I don't think it will do the trick but it's worth giving a try.
From last post I tried giving full access to "Everyone" on concerned folders, for test purpose, but  still the same behaviour. Maybe an exorcist in last resort  ... ?  🙄
Thanks anyway for your help
JonEmch
Perhaps an exorcist, or the next best thing: Working with Esri Technical Support! Are you able to open a ticket at this time?
Keep on keeping on!
PierreLarondelle
New Contributor III
Yes I'm in touch with our local distributor, we'll see what can be done.
Have a nice day !
JonEmch
You as well! If you dont mind, please follow up with the case solution once it gets resolved. Alternatively, DM me your case number and I will post it once it is finished.
Keep on keeping on!
LeeIrminger2
New Contributor II
What was your solution?
PierreLarondelle
New Contributor III
Hi @LeeIrminger2 , the problem was in Datastore VM's certificate. After upgrading  the machine's certificate the problem was gone.
LeeIrminger3
Thank you - was that a single machine deployment?
PierreLarondelle
New Contributor III
No, we have splitted ArcGIS Entreprise over 3 VMs : ArcGIS Server + Portal / Geodatabase / Datastore
