Collaboration between AGOL and Enterprise, item shared ask for credentials
1021
10-24-2023 01:44 PM
DiegoLlamasOlivares
We have a collaboration between ArcGIS Online organization and ArcGIS Enterprise 10.9.1. AGOL host, Enterprise guest. When a guest share a hosted feature service to AGOL, when I try to use the layer from AGOL it asks for credentials. I did a test doing a collaboration between  2 enterprise 11.1 -10.9.1 and i was able to solved the error when i used option "Allow participants to view services without signing into this portal: Yes" but in AGOL i do not have that option.
How can I get that the item that i am sharing as a guest to not ask for credentials when the host is using the layer?
Regards.
diego Llamas
David_McRitchie
Hey Diego,
Are you sharing this via an Enterprise Geodatabase? If so then I would share both Map Image and Feature Layer to the collaboration workspaces.
Hope that helps
David
Esri UK -Technical Support Analyst
DiegoLlamasOlivares
No, this is a hosted feature layer.
