Datastore : "You don't have permission to perform this task"
3218
11
01-26-2021 04:15 AM
PierreLarondelle
Hi, when I tried to perform any of the tasks regarding datastore config, I get this message.
I'm on windows server 2019, the cmd is from admin elevated prompt, all concerned folders have full rights.
Any ideas ? Thanks.
JonEmch
Could you try running this prompt while logged into the windows service account that runs ArcGIS Datastore? It is a bit strange that running it as an admin results in a permission failure.
Please let me know if this changes the behavior.
Keep on keeping on!
PierreLarondelle
Nope, even with domain account. I'm in touch with the IT to try a group Managed Service Account as described in documentation. I don't think it will do the trick but it's worth giving a try.
From last post I tried giving full access to "Everyone" on concerned folders, for test purpose, but  still the same behaviour. Maybe an exorcist in last resort  ... ?  🙄
Thanks anyway for your help
JonEmch
Perhaps an exorcist, or the next best thing: Working with Esri Technical Support! Are you able to open a ticket at this time?
Keep on keeping on!
PierreLarondelle
Yes I'm in touch with our local distributor, we'll see what can be done.
Have a nice day !
JonEmch
You as well! If you dont mind, please follow up with the case solution once it gets resolved. Alternatively, DM me your case number and I will post it once it is finished.
Keep on keeping on!
LeeIrminger2
What was your solution?
PierreLarondelle
Hi @LeeIrminger2 , the problem was in Datastore VM's certificate. After upgrading  the machine's certificate the problem was gone.
LeeIrminger3
Thank you - was that a single machine deployment?
PierreLarondelle
No, we have splitted ArcGIS Entreprise over 3 VMs : ArcGIS Server + Portal / Geodatabase / Datastore
