ArcGIS Desktop (ArcMap) 10.8.2 (the latest and last version) will switch to 'Mature' support in March 2024.
That means no more software updates or patches.
ArcMap PLC - https://support.esri.com/en-us/products/arcmap/life-cycle
ArcGIS 10.6 and 10.6.1 (Desktop (ArcMap) and Enterprise) will be RETIRED on January 1, 2024.
Please refer to the Product Life Cycle on the Esri Support site.
Enterprise PLC - https://support.esri.com/en-us/products/arcgis-enterprise/life-cycle
Yes, the whole internet, in either direction, with optional analysis on the way. What's not to like?
No code automation for the Export Subnetwork tool of the Utility Network taking advantage of new and improved features of the dataset and the Data Interoperability extension. This solution built with Pro 3.1 and UNv6 utility network, optimizes the original solution published in this blog, Leveraging Data for External Systems - Automating Export Subnetwork using Data Interoperability - Pa...
Share data without schema hassles.
Hang onto that word "local"!
It's a bit like English either side of the Atlantic (or French for that matter)...
Change detection is powerful but with power comes responsibility....
One process to rule them all!
Which should I use? Do I need both?
