Data Interoperability Questions
123
651.2K
86
POST | I have installed ArcGIS Pro 3.5. I selected the installation option "Anyone who use this machine" according to the of... by geoallanvictor New Contributor 1 2 | 1 | 2 | 75 | |
DOC | QuestionWhy is the Workbench app frozen, how to fix this and what can I do to avoid this?AnswerCustomer case: Data in... by RenatoSalvaleon3 ![]() 0 0 | 0 | 0 | 81 | |
BLOG | Problem DefinitionGraph ScenarioThe ETL ToolThe Graph in ArcGISDiscussionProblem Definition Knowledge Graph entities ... by BruceHarold ![]() 2 2 | 2 | 2 | 2252 | |
IDEA | HiI didn't find anything online, could data interoperability be integrated into ArcGIS Notebook server? by Oiligriv Frequent Contributor 1 5 | 1 | 5 | 200 | |
BLOG | The 2025 Esri User Conference is right around the corner, and we are excited to connect with you. UC is filled with m... by EthanMink ![]() 1 0 | 1 | 0 | 249 | |
POST | I'd like to create a DI workspace where the user can select a layer in the current map, then take that layer in the w... by MattHowe Frequent Contributor 1 3 | 1 | 3 | 295 | |
POST | I'm trying to add an existing workspace created using data interoperability to a new atbx toolbox in ArcGIS Pro 3.3.1... by MattHowe Frequent Contributor 1 9 | 1 | 9 | 527 | |
POST | I am using sqlalchemy in a Python script that I created in VSC using a clone of the arcgispro-py3 environment.When I ... by TomGeo Frequent Contributor 0 1 | 0 | 1 | 243 | |
POST | Hello,We have a server with data interop and ArcGIS Pro installed and I have a work bench that I can successfully run... by kmsmikrud Frequent Contributor 1 2 | 1 | 2 | 260 | |
POST | I need to install scipy into the Data Interoperability Workbench and tried the approach one would take with FMEfme.ex... by ThomasBeckerDK Emerging Contributor 0 6 | 0 | 6 | 614 | |
DOC | This post is a stepping stone between the ETL Patterns community space and Esri's Well-Architected Framework site, wh... by ShareUser ![]() 0 0 | 0 | 0 | 178 | |
BLOG | Sometimes you want to get complex data into an ArcGIS Pro session, but on a trial basis - say into the built-in memor... by BruceHarold ![]() 2 0 | 2 | 0 | 603 | |
BLOG | It is always satisfying to share powerful new ways to solve problems, especially so when the solution has been "hidin... by ShareUser ![]() 0 0 | 0 | 0 | 217 | |
POST | Hi,In Pro 3.3, i set a snowflake connection. Test is successfull.But when i want to save, i have this message => Unab... by RémyGourrat Occasional Contributor 0 4 | 0 | 4 | 566 | |
POST | Hi everyone,Greetings.I have published an etl tool in arcgis data interoperability server.But from there I can't run ... by WahidIbneZakir New Contributor 0 1 | 0 | 1 | 469 |
Welcome to the community page for the ArcGIS Data Interoperability extension for Pro and Enterprise. ArcGIS Data Interoperability connects to hundreds of apps and data formats using Safe Software's FME technology. Pose questions here and browse helpful blog posts and videos, and above all interoperate with your colleagues worldwide! The on-line courses below will take you from new user to expert using the extract, transform, and load (ETL) geoprocessing framework delivered by the extension.
User | Count |
6 | |
1 | |
1 | |
1 | |
1 |
