@Scott_Sambell You're welcome 😉
List created with Claude assistance: June 30, 2026 ~4:15pm EST.With the AI caveat in mind, if something looks off, feel free to let me know!To quote @GrantHoward1 :
ArcGIS Dashboards
ArcGIS Online / Map Viewer
ArcGIS Experience Builder
ArcGIS Field Maps
🗺️ ArcGIS Instant Apps
Great work @Katie_Clark . Thanks for this
@WillyG here is the list!
If you can add ExB would be great. Tons listed over on that board also.
Big post here also https://community.esri.com/t5/arcgis-online-questions/june-2026-agol-update-issues-so-many-issues/td-p/1710391
Thanks for this!
@DougBrowning Same disclaimer about working with Claude, but I added an ExB section and also added more to the Field Maps section from that Community board. I also added in a few bug numbers that have been assigned as a result of all this, but that was manual work (not Claude) so I'm sure I'm missing some. The list is gettin' long.....
Re: June 2026 update - Category Selector no longer... - Esri Community
June 2026 update - Indicators randomly stop workin... - Esri Community
Has anyone else experienced automation failures after the recent ESRI update? We’ve seen major impacts to our Java Selenium framework because the underlying DOM structure has changed. Many of our test cases are now failing since the vaadin-grid element is encapsulated inside a Shadow DOM, making it inaccessible through standard Selenium locators. We’re also unable to interact with or validate map popups, as they are now rendered within closed shadow roots. Overall, this update has disrupted our core automation workflows, and test execution is taking much longer due to retries, timeouts, and UI changes across multiple features. Is the community seeing similar issues or has anyone found effective workarounds?
Experience Builder copy and paste no longer working: https://community.esri.com/t5/arcgis-experience-builder-questions/copy-and-paste-not-working-no-list-of-target/m-p/1712096#M23715
Has anyone had a problem with table widgets in Experience Builder not honoring the sort order? I have the data sorted by a date time field descending but the table is sorted by date ascending until I manually click to sort. It is the same whether I sort by ascending or descending in the data settings.
Great work putting this together Katie. Here's another one: https://community.esri.com/t5/arcgis-dashboards-ideas/reinstate-the-ability-to-add-dynamic-text-and-html/idi-p/1711492
This is another issue likely from the update: Re: Bulk Editing Deleting Fields - Esri Community
Possible new add https://community.esri.com/t5/arcgis-experience-builder-questions/experience-builder-edit-widget-configuration/m-p/1713409#M23821
We also had all of our credit budgeting settings reset and all users set to "No Limit" without our knowledge costing us over 1,000 credits.
Has ESRI sent out any communication regarding this? This is the first time I've noticed a significant effect from an update. The change to dashboard date selector is crazy, how do you let that get through testing?
Another item for the pile in Dashboard: https://community.esri.com/t5/arcgis-dashboards-ideas/no-longer-displaying-last-update-on-dashboard/idi-p/1715006/
Another one that's affecting our dashboards from the Emergency Mangement Operations Solution created by Esri:
BUG-000186253 ArcGIS Dashboards widgets configured with a Filter action under Map actions: "When map extent changes" fail to load on initial dashboard load, displaying an indefinite loading state until a manual zoom or pan interaction is performed on the map.
https://support.esri.com/en-us/bug/arcgis-dashboards-widgets-configured-with-a-filter-acti-bug-000186253
My team and I have also noticed general slow downs with web maps and applications across the board. For example, layers take longer to load, the Arcade window will sometime take up to a minute to load, running Arcade to test code in the Arcade window is taking longer to initiate and sometimes longer to run (though this is inconsistent), and popups are taking longer to popup.
It almost seems like they changed the RAM, CPU, and/or volume specs of the AWS machines to be slower or less performant (maybe to save money??). Or, it may be that Chrome/Chromium updates are possibly slowing things down, though I have not done thorough testing on different browsers.
What I know is that I and other have observed something significantly changed at the June 2026 update...
AGOL "used by" dependencies doesn't show for tile layers and other types
Experience builder is still slow than my identical WAB applications. This needs to be fixed as I have users refusing to use user facing Experience Builder apps because they are too slow and slower than the WAB apps.
