Road Labels Suddenly Broken in MapViewer
805
13
06-29-2026 02:00 PM
twilliamson_topv
Recently, I was going through one of my Experiences and saw that my road labels were really funny looking.
Some of them were missing letters randomly and north/south roads that were longitudinal had two labels each, with the labels facing different directions. If the label is set to "Center Along" for Placement, it results in a jumbled mess. See screenshots. Notice in the second screenshot, when I set placement to Appear Above, that there are two labels for each north/south road segment. It is only assigning two labels for absolutely vertical roads, or close to it. (90 degrees to the equator)
I now see that this is suddenly affecting all of our products with labels that were configured in MapViewer. (really just roads).labelsglitch-mapviewer.pnglabelsglitch-mapviewer.pnglabelsglitch-mapviewer2.pnglabelsglitch-mapviewer2.png
There have been no recent updates that we have pushed to the hosted feature layer for Roads, so we believe that something has changed in AGOL to cause this.
Please help or escalate.
RenderImages
I noticed line labels displaying poorly after the June 2026 AGOL update that happened last week. Lines are labeled with skipped letters/missing random letters (see SS.png attached). This is happening across the board for all labeled line layers; it happened with a line feature class that I had published from Pro, but also happened with a hosted feature layer that I created in AGOL with labels configured solely in AGOL. Hopefully Esri corrects this line labeling display issue.
StephanieW
Hi @twilliamson_topv and @RenderImages What you are describing sounds similar to two issues we are current tracking, they are under review by the product teams.
BUG-000185883: Some line feature labels are duplicated and overlap when using Concatenate in an Arcade labelling expression
and
BUG-000185886: When zooming in and out along line vertices, labels for line feature classes are missing some letters - ArcGIS Online Map Viewer
twilliamson_topv
Happy to hear at least that this is unexpected behavior and not something broken on our end. I will turn labels off on these products until a fix is released. Thank you.
Jordan_Snelick
This is happening to my organization as well for all line features with labels. Line feature labels are duplicated and overlap even when not using concatenate or any arcade expression. Both Bugs are currently occurring.
Discussed and alerted an Esri Rep  from Esri support services yesterday. Keeping an eye till fixed.
RussRoberts
Esri Notable Contributor
We are hoping to have a fix for this to roll out tonight. If you have a map you can share I can check it out against the fix. You can invite russell_jsapi into a group thanks!
twilliamson_topv
Hi Russ, you are welcome to use our public Streets map to test it.
https://experience.arcgis.com/experience/d9181a785cbe465f8c9d649e1bc2b902
The problem is most noticeable in the neighborhood at 34.58994, -112.34602
Regards,
RussRoberts
Thanks!  Quick test looks like its the fix is working.
RussRoberts
We plan on rolling this out tonight with our patch.
RussRoberts
The fix went out last night and the sample maps from the posts are looking good. lmk if you see any issues.
