Parallel Processing Factor
7231
10
03-27-2019 10:56 PM
NathanFleischman
I am using Parallel Processing Factor to speed up a process that has been taking too long. I have a question though. I have a workstation computer that has a 16-core processor. Each core has two logical processors. How many processes would it do if arcpy.env.parallelProcessingFactor was set to 50%, 75%, or 100%, given that fact?
DanPatterson_Retired
NathanFleischman
I have seen the page, but it does not mention logical processors of which there 32, 2 for each core. How do I take that into account?
NathanFleischman
Also, I put it in a user-defined function in Python. What do you think might be wrong with that?
NathanFleischman
Also, I am using the Mosaic to New Raster tool.
NathanFleischman
Does that tool honor the Parallel Processing Factor?
every tool... including
Mosaic To New Raster—Data Management toolbox | ArcGIS Desktop
has a section at the bottom of the help topic which states environment factors that are supported with an disclaimers....
Environments
Extent
Not valid for enterprise geodatabase
NathanFleischman
Yes I noticed. However, I am using ArcGIS 10.6. I do not have ArcGIS Pro, unfortunately. The bad news with that is that Parallel Processing Factor is not listed in the Environments section on the page for Mosaic to New Raster. That environment is only available starting with ArcGIS 10.7 for that tool. Bother.
NathanFleischman
However, if I were to get ArcGIS Pro or ArcGIS 10.7, how do I take logical processors into account.
DuncanHornby
MVP Notable Contributor
The link that Dan Patterson gives clearly talks about number of cores ... "processes will be divided between hardware cores (processors) built into the machine". You say you have 16 cores then setting this environment setting to 100% will use all 16 cores. As that page never mentions "logical processors" I would assume it would mean that tools would not distribute work over 32 logical processors.
