weird results with Align Features
I'm getting some weird results with the Align Features GP tool (arcpy.edit.AlignFeatures) in Pro 3.5.6. I have 2020 Census Blocks that use geometry from the Census Bureau and I want to align the blocks to my streets layer. We use the streets for geocoding, so I want these two to line up to know what census blocks touch a…
Spatial Join: is many-to-one possible?
I have a point layer and a streets layer that I want to do a spatial join on. Because the points can fall on street intersections, I want to join one-to-many such that I get a record for each street it touches. This works, but the output is a point layer, with one point for each street it touches. What I really want is…
Quantifying overlapping polygons
Hello. I’m following up from a recent post regarding the quantification of polygons (features) that overlap. As I currently understand it, the Count Overlapping Features (COF) tool is a misnomer since the result enumerates the number of overlaps rather than the number of features which overlap. So currently, using COF, 5…
Count overlapping features
Hello. I have around 250,000 polygons (representing building footprints) to each of which I have applied a 10m buffer (no dissolve). I then use the Count Overlaps tool to investigate how many of these buffers intersect once, twice etc with neighbouring buffers. The results do not appear reliable. In many cases, buffers…
Cost Path Analysis
I am trying to calculate a concept of Spatial Efficiency, which is based on sum of distances for main entity to secondary entities is the equal to sum of secondary entities to the remainder. This worked fine in spatial analyst but I having trouble in model builder the optimal path as line will not activate The same occurs…
Project Tool Process for Transforming Layers from NAD 1983 to NAD 1983 (2011)
Hi, this is a question mostly to verify (or counter) my understanding of a very, very small difference in the results from suggested workflows for transforming NAD83 data to NAD83 (2011). I am not trying to split hairs over this question, but just trying to know why. I realize that I am exceeding the resolution of the…
Dividing polygons into small areas of 200 to 300 neighboring residents
Hi, I have polygons created with the Generate Service Area tool that I'm looking to divide up into smaller polygons that each contain 200 to 300 residents. I have an address point layer with the number of residents at that address in the attribute table that I want to use to create the smaller polygons. What would be the…
Cushion isolated diagonal connections of same class cells in a categorial raster
I have a categorical raster I use for a land use map. The categorical raster is further being polygonized and then adjusted in a graphical software for the target map. The raster datas' resolution is borderline for the target map scale, so we do not any generalization before hand and try to retain as much detail as…
Count of records in sde views fails
Good morning, We have several Python scripts that count records in sde views and were working fine before version 3,6. But now they return an error message: ERROR 160077: An underlying database error occurred. Our sde views are located in a SQL server database. import arcpy # Replace with your SDE view path or layer name…
Calculate distance between points
Hi: Within Pro desktop, I'd like to calculate the distance between points. The points are in the same feature class and would want to limit distance to neighboring points within, say, 40 meters. There's a total of about 200 points. To make it even more fun, generating a line labeled with the distance between each…
Enable Attachments disabled after generating match table
I am trying to attach PDF assessment packets to polygon features on a map. I use the enable attachments geoprocessing tool, this completes successfully. I have also attempted enable attachment through the manage window on the feature service. I generate the match table via the geoprocessing tool. The attach table and…
Address Locator
Hi there, I'm trying to create a local address system for my organization. How can i do this? Also I want the address system to automatically autofill when someone starts typing in their address. Please help. Thanks!
Published Python Script to Enterprise 11.5 wont run, but will in Pro
Hello, I created a simple python script that will just Stop a service, as in the future I want to build upon this script. This python script works when I run it from an IDE, it works in ArcPro as a direct python script, and it works as a Toolbox's Script tool. It will even print out all my print statements as it goes…
Migrating Hosted Feature Layer with Attachments and Related Table – GlobalID / Append Issues
Hi folks, Here goes my journey, any help will be immensely appreciated. The task I’ve got is to transfer c.2000 records from one hosted feature layer to another. The source layer has become not fit for purpose, with redundant fields and lack of coherence. Instead, I have created a new GDB on ArcGIS Pro with a Feature Class…
Display Multiple Feature Class Fields in Geoprocessing Pane
Hello everyone, I'm creating a custom arcpy script geoprocessing tool that allows a user to do the following: 1. Geocode an address table or process an XY table. 2. Do N spatial joins based on how many feature classes the user selects. I was successful in creating the script to handle #1. But for #2, while I can ask the…
AI in GIS
I'm interested in learning how AI and Generative AI can be integrated with GIS including practical applications and use cases, especially in geoprocessing. I'd also appreciate a roadmap or a learning path and the technologies needed or resources in this regard.
Unintended External Triggers on Public Geoprocessing Services
We have several public-facing geoprocessing services that allow our application to send emails when certain events are triggered. These services have been running for years without any issues. Recently, however, they’ve started being triggered from outside the application, and the services are running with default…
display three contigous polygons with boundaries side by side instead of overlapping
I'm trying to display contiguous polygons with identical boundaries so the boundaries of each polygon are visible. I've been playing with Offset in symbology to try to accomplish it without luck. Call them polygons A, B and C. Polygon A borders B and C and Polygon B borders A and C. I can get A to line up beside B and C…
Services missing from ExportWebMap GP Tool
I have a GP tool that creates a pdf map. My public AGO services will not show up when exported but the NOAA weather station AGO services do show up. I am hosting my GP tool on my portal and referencing the public AGO services. Any reason why some show up and some don't?
010819: The input path contains spaces. - Buggy
Not sure why I am getting this error in this input parameter. I also get this warning when I add input rasters - my workaround for raster is to add the full path. But I am not sure what to do in this case.
Clearing Date Field (Python Toolbox)
Is there a way to set a date field to None within a python toolbox tool? I found a thread from 2017 where the answer was no, but maybe something has changed since then. For context, my agency has a database of regional developments which we keep updated through a custom python toolbox. If a development encounters a delay…
Need help converting a csv with lat long to a shape file with state plane
Greetings everyone....I need help with a csv file. It has columns for lat/long and i've imported to arcmap with a map in Ark North SPcoordinates. When I try to do geometry to this file to convert the xy to LL to state plane, the results I'm given still shows me the LL. I can't figure it out. Would someone help me out and…
Script Tool Python Question
I am trying to create a script tool to use in a model. The purpose of the script tool is to take files that have been exported to a folder and zip them into a different folder. I am getting an error: Traceback (most recent call last): File "C:\Scratch_Catalog\ZipFile_Export.py", line 33, in <module>…
Disable "Use the selected records" toggle from PYT
Hi all, Is it possible to disable the "Use the selected records" toggle from a Python toolbox? I have some tools which should always use all features from the input, I've instructed users to ensure that toggle is turned off but would like to remove the option altogether. Thanks!
MaxEnt and Jackknifing
Hi Everyone, I'm new to using Presence-only Prediction in ArcGIS Pro. I've been reading up on MaxEnt, and it seems that the standalone tool had a 'Do jackknife to measure variable importance' option built into the tool. This would help determine the highest performing variables. Is there a version of this in the ArcGIS Pro…
