Hide Select by Rectangle and Selectable Layers section in Screening Widget
1324
5
01-09-2018 09:40 AM
MarkCooper5
Hi
I need to hide the Select by Rectangle and Selectable Layers section in the Screening Widget draw tool as we don't want users to use them. Is this possible in the HTML?
Mark
Tags (1)
RobertScheitlin__GISP
Mark,
   Here is the css rule to add to hide those items:
.jimu-multiple-layers-featureset-chooser,
.esriCTParentDivOfChooseSymbol,
.esriCTWidgetAndBufferSeparator[data-dojo-attach-point='seperatorAfterSelect'] {
  display: none;
Mark,
  So just remove the two items outlined in the image?
MarkCooper5
Almost! The tool I want to remove is not the one you have highlighted, but the one two to the right (with the 3 polygons and the arrow). The other bit is correct.
I may be wrong, but if I can just hide it in the html, it is less likely to cause any issues than if I remove it elsewhere!
Mark,
  display: none;
MarkCooper5
Fantastic Robert - you are a genius!
If I wanted to hide the buffer tool, would that be in the same place?
Mark,
   At would be this rule then:
.esriCTWidgetAndBufferSeparator,
.esriCTAOIBufferChangeParentContainer,
.esriCTBufferDistanceLabelTextBoxContainer {
  display: none;
Don't forget to mark this question as answered by clicking on the "Mark Correct" link on the reply that answered your question.
