Roberts Custom WAB Widgets
408010
475
12-31-2014 11:28 AM
RobertScheitlin__GISP
Barnaby,
   Nope I have not seen that one... Does it only happen in IE?
BarnabyRockwell
Yes.
BarnabyRockwell
Note that the Flex 3.7 version of the widget shows the same behavior in IE11.
Barnaby,
   I will have to test in Google Maps and see if they have the same issue with IE 11. Sounds like a css issue on their side.
BarnabyRockwell
Robert,
I had assumed that it was a problem on their end...
Note that the Google navigation tools work properly, they just look weird.
Cheers,
Barnaby
BarnabyRockwell
Hi Robert,
Congrats on release of v1.1 of Identify widget!!!
I cannot get some attributes from a thematic raster layer to display in ID results.
Layer: 3/27/13 - reduced vegetation suppression - AA11 (ID: 2)
In ID widget GUI, the only attribute that shows up from the above layer is Pixel Value, but I need both Pixel Value and MaterialID attributes to show.  Any ideas?
Edit:  However, if I add Layer 0 (topmost layer in REST) to the widget, I do get ID results for all attributes, which is a great start!  Now all I need is to be able to select which attributes to display for each layer.
Best regards,
Barnaby
Barnaby,
  Just like in Flex the REST endpoint for raster layers does not return any fields but I do know that if it is a raster layer then it will have the "Pixel Value" field, so that is why I had it to the field list for you. If you want more fields added then you will have to manually add then to the config_Identify.json (similar to the way you did in Flex).
BarnabyRockwell
Robert,
Ok.  I'll try that.
Many thanks,
Barnaby
Huge wish:  cool tool to import Flex ID widget XML into WAB config_Identify.json.
BarnabyRockwell
Robert,
Looking good with edited config_Identify.json:
"name": "Landsat 8 - AA13 - 2014 Calibration - Mosaic 9",
"url": "http://MyServer/arcgis/rest/services/usminmap/Landsat8/MapServer",
"id": 2,
"zoomscale": "",
"forcescale": false,
"fields": {
"all": false,
"field": [
"name": "Value",
"alias": "Pixel value"
"name": "MaterialID",
"alias": "Material ID"
"links": {}
However, the "name" field in red above is not holding through to ID results, which only show the REST layer name.
Cheers,
Barnaby
Barnaby,
   Thanks for reporting this. I will have that fixed in the next release. in the mean time it is a simple one line change you can make your self. In the Widget.js file on line 1026 replace that line with this:
idResult.title = identTitle || identifyResult.layerName;
