Roberts Custom WAB Widgets
407960
475
12-31-2014 11:28 AM
RobertScheitlin__GISP
@Nicholas_I_Seigal
Yes I am still maintaining my WAB widgets. As far as moving forward:
https://community.esri.com/t5/experience-builder-custom/gh-p/eb-custom-widgets
What type of tweaks?
DavidDas__GISP
Hi Robert,
I have an enhancement request.
In the past I had requested you not to apply a limit to the number of rows displayed in the drop-down lists in your Enhanced Search Widget and Identify Widget.
I am taking it back.
Our users prefer the drop-down lists to be limited like the standard ESRI Filter Widget.
It is limited to displaying 10 rows.
This behavior gives a cleaner look. I know you had mentioned on the usefulness of applying a limiter on these drop-down lists.
You were right.
Could you please modify your code in the next release of your Enhanced Search Widget and Identify Widget to change the behavior?
Here is how the Enhanced Search Widget behaves at version 2.21:
Example 1
Example 2
Here is how the Identify Widget behaves at version 2.17:
It would help to limit the drop-down list to 10 rows to mimic the behavior of the Filter Widget.
Best regards,
David Das
DavidDas__GISP
Hi Robert,
Thanks so much for your latest enhancements to the Enhanced Search Widget and the Identify Widget that limits the Max Rows to 10 for the dropdown lists.
I found just one issue while verifying your fixes.
While using Enhanced Search version 2.21.1 (11/16/2021), I see the Search Layer dropdown is not getting limited to 10 rows.
All other dropdowns are working as expected honoring the 10 row max limit.
Here is the Search By dropdown.
Before
After
I have verified your fix on the Identify Widget 2.21 (11/16/2021)
Before
After
Thanks again for making these changes!
Best regards,
David Das
LefterisKoumis
Hello Robert. Any plans to create a widget for the popup panel for ArcGIS JS 4.x?
I saw examples for the JS 4.x with side panel display of features by they are all for a single layer.
@LefterisKoumis I have a Feature Panel widget for EB. It does more than one feature.
LefterisKoumis
Thanks. Unfortunately, my agency mandates ADA compliance and ExB is not there yet. That's why I focus on calcite with ArcGIS JS API, no templates.
