Roberts Custom WAB Widgets
407244
475
12-31-2014 11:28 AM
BarnabyRockwell
Robert,
That fix works perfectly.  EXCELLENT!
Many thanks,
Barnaby
RobertScheitlin__GISP
All,
  Don't forget to mark replies as helpful if they are.
BarnabyRockwell
Robert,
I seem to be getting two ID results for every polygon I click on in a tiled vector layer.  Can you duplicate this?  There should only be one result per polygon.
Layer: Generalized lithology (ID: 1)
"name": "Generalized lithology",
"url": "http://MyServer/arcgis/rest/services/usminmap/SGMC_March2014_Geology/MapServer",
"id": 1,
"zoomscale": "",
"forcescale": false,
"fields": {
"all": false,
"field": [
"name": "State",
"alias": "State"
"name": "Orig_Label",
"alias": "Original label"
"name": "Unit_Name",
"alias": "Unit name"
"name": "Generalized_Lithology",
"alias": "Generalized lithology"
"name": "Age_Min",
"alias": "Minimum age"
"name": "Age_Max",
"alias": "Maximum age"
"name": "Major1",
"alias": "Major1"
"name": "Major2",
"alias": "Major2"
"name": "Major3",
"alias": "Major3"
"name": "Minor1",
"alias": "Minor1"
"name": "Minor2",
"alias": "Minor2"
"name": "Minor3",
"alias": "Minor3"
"name": "Minor4",
"alias": "Minor4"
"name": "Minor5",
"alias": "Minor5"
"name": "Indeterminate",
"alias": "Indeterminate"
"name": "Reference",
"alias": "Reference"
"links": {}
Edit:  note that I also have a popup configured for that tiled layer.  Don't know if that matters, but...
Cheers,
Barnaby
Barnaby,
   Yes I can duplicate that. I think I found the issue but will have to test more.
BarnabyRockwell
Robert,
Great.  Let me know if you need more info.
Cheers,
Barnaby
BarnabyRockwell
Robert,
ID widget 1.1.0.1 works like a dream.  EXCELLENT!
I developed a suite of RegEx script commands for use in Notepad++ which quickly convert the XML config code from the Flex version widget into  json code for the WAB version of the widget.  This saves LOTS of time when converting viewers having ID widget from Flex to WAB.
Instructions:
  1. Open config_identify.json in Notepad++
  2. Copy layer entries from Flex XML into layers section of json file
  3. Run RegEx search/replace in order shown in Excel spreadsheet (top to bottom), using "Regular expression" Search mode.
Many thanks,
Barnaby
Edit:  (I would have posted this as a comment on the ID widget document page, but it is apparently impossible to add attachments to such comments.  )
AndrewNiederhauser1
Barnaby,
Are you aware of any RegEx scripts that have been developed to migrate the Flex eSearch setups to the new WAB eSearch?
Andrew
BarnabyRockwell
Andrew,
No, I am unaware of any such scripts.  I don't use eSearch, so I have had no need to make an updater script.
Cheers,
Barnaby
AndrewNiederhauser1
Okay. Thanks for the reply!
AndrewNiederhauser1
Robert,
Do you have any interest in putting together a widget that could load .config files for an app based on user credentials? Something similar would be the crime mapping app you setup.
Calhoun County Sheriff
Wherein a user could enter their credentials and the WAB would retrieve the .config file appropriate to that user and load the related widgets and layers contained in the .config. Ideally, this would be setup for the non-developer.
Apologies for possibly oversimplifying this task.
Andrew
