export map layout with loop definition query
10042
22
09-15-2021 02:08 AM
MahmoudHegazy
i would like to complete my script to zoom to layer per definition and export pdf but the script give me bugs when it export pdf and not zooming can any help me
import arcpy, os
mxd = arcpy.mapping.MapDocument("CURRENT")
df = arcpy.mapping.ListDataFrames(mxd)[0]
layerName = arcpy.GetParameterAsText(0)
fieldName = arcpy.GetParameterAsText(1)
imgLocation = arcpy.GetParameterAsText(2)
whereList = []
layerFile = arcpy.mapping.Layer(layerName)
layerFile.definitionQuery = ""
print df.name
with arcpy.da.SearchCursor(layerName, fieldName) as cursor:
for row in cursor:
for item in row:
whereList.append(item)
for wl in whereList:
layerFile.definitionQuery = fieldName + "= '" + wl + "'"
df = layerFile.getExtent()
df.extent = outFile
outFile = imgLocation + "\\" + wl + ".pdf"
arcpy.mapping.ExportToPDF(mxd, outFile)
del mxd
Tags (4)
7 Solutions
DavidPike
MVP Notable Contributor
This bit makes no sense
#variables are all messed up
  df.extent = outFile
#should be
  new_extent = layerFile.getExtent()
  df.extent = new_extent
  arcpy.RefreshActiveView()
MahmoudHegazy
the extent run very well but still getting error to export pdf
File "c:\program files (x86)\arcgis\desktop10.4\arcpy\arcpy\mapping.py", line 1156, in ExportToPDF
layout.exportToPDF(*args)
AttributeError: Invalid destination path
Failed to execute (Script)
DavidPike
what path are you supplying for imgLocation?
I prefer to use the os.path.join() method when constructing paths:
outFile = os.path.join(imgLocation, wl + ".pdf")
arcpy.AddMessage(outFile)
DavidPike
probably adjust the scale factor e.g.
df.scale *= 1.15
DavidPike
Can you share your final code?
You're saying that the second image is the pdf produced?
Are you sure you're specifying the same MXD which contains the layout?
The layout should be used as default in arcpy.mapping.ExportToPDF(mxd, outFile), but maybe try this just in case:
arcpy.mapping.ExportToPDF(mxd, outFile, "PAGE_LAYOUT")
and what if you try JPEG or PNG etc. ?
outFile = os.path.join(imgLocation, wl + ".jpg")
arcpy.mapping.ExportToJPEG(mxd, outFile)
DavidPike
ah I think I made a silly error, I'm unable to test this.
side note - why are you using mxd.save() and why have you got outFile variable created then overwritten 2 lines later?
import arcpy, os
whereList = []
print df.name
    for row in cursor:
        for item in row:
    mxd.save()
    df.scale *= 1.5
    for elm in arcpy.mapping.ListLayoutElements(mxd, "TEXT_ELEMENT", "title"):
        if elm.name == "title":
           elm.text = wl
del mxd
DavidPike
.strip() would only remove trailing and leading stuff.  Probably best to do something like this:
name = ''
for char in wl:
  if char.isalpha():
    name+=char
outFile = imgLocation + '\\' + name + '.pdf'
DavidPike
  df.extent = outFile
#should be
MahmoudHegazy
DavidPike
MahmoudHegazy
it worked thanks but when it get extent , the extent 100% i want to customize it to 115% to  make the feature fully visible
DavidPike
df.scale *= 1.15
MahmoudHegazy
how i export the pdf from the layout ?
MahmoudHegazy
 this my layout and after i export the layout to pdf after i export it looked this
and the size page is A1
DavidPike
MahmoudHegazy
you helped me more thanks this the final script by DavidPike
 i want use the dynamic table and this not in armap this onlyy in arcgis pro so i want convert my final script to arcgis pro
import arcpy, os
whereList = []
print df.name
for row in cursor:
for item in row:
df.scale *= 1.5
del mxd
