export map layout with loop definition query
10063
22
09-15-2021 02:08 AM
MahmoudHegazy
i would like to complete my script to zoom to layer per definition and export pdf but the script give me bugs when it export pdf and not zooming can any help me
import arcpy, os
mxd = arcpy.mapping.MapDocument("CURRENT")
df = arcpy.mapping.ListDataFrames(mxd)[0]
layerName = arcpy.GetParameterAsText(0)
fieldName = arcpy.GetParameterAsText(1)
imgLocation = arcpy.GetParameterAsText(2)
whereList = []
layerFile = arcpy.mapping.Layer(layerName)
layerFile.definitionQuery = ""
print df.name
with arcpy.da.SearchCursor(layerName, fieldName) as cursor:
for row in cursor:
for item in row:
whereList.append(item)
for wl in whereList:
layerFile.definitionQuery = fieldName + "= '" + wl + "'"
df = layerFile.getExtent()
df.extent = outFile
outFile = imgLocation + "\\" + wl + ".pdf"
arcpy.mapping.ExportToPDF(mxd, outFile)
del mxd
Tags (4)
DavidPike
MVP Notable Contributor
Did what I say work? If so what was the issue and what solved it?
Re converting it to Pro, it will be more than a simple changing of a few things, as there's a different mapping class, camera objects etc.  I'd recommend putting this thread to rest and posting an entirely new question.
MahmoudHegazy
thanks i will do it but befor i want to add a dynamic text in arcmap each layout want the dynamic lebel change i tried to this but not organized my code
import arcpy, os
whereList = []
print df.name
for row in cursor:
for item in row:
mxd.activeView = "PAGE_LAYOUT"
for elm in arcpy.mapping.ListLayoutElements(mxd, "TEXT_ELEMENT"):
if elm.text == "title":
elm.text = elm.text.replace(elm,wl)
arcpy.RefreshActiveView()
mxd.save()
new_extent = layerFile.getExtent()
df.extent = new_extent
df.scale *= 1.5
outFile = os.path.join(imgLocation, wl + ".pdf")
arcpy.AddMessage(outFile)
arcpy.mapping.ExportToPDF(mxd, outFile, "PAGE_LAYOUT")
del mxd
DavidPike
If you properly format your code I might be able to assist. Code formatting ... the Community Version - Esri Community
MahmoudHegazy
import arcpy, os
whereList = []
print df.name
    for row in cursor:
        for item in row:
#the code blow for lebel Dynamic in the layout
        mxd.save()
        df.scale *= 1.5
del mxd
DavidPike
Having the for loop for the text element as the initial loop is a bit off imho. also note your element would have to be named 'title' (in the text element properties on your layout there is a name box where you can specify this)
    mxd.save()
    df.scale *= 1.5
           elm.text = wl
MahmoudHegazy
i made test and change  the lebel to "title" as you see in the screen shot but the pdf exportefd without chang
e the dynamic lebel can you retest the code and see it again
my final look code is this
import arcpy, os
whereList = []
print df.name
    for row in cursor:
        for item in row:
    mxd.save()
    df.scale *= 1.5
           elm.text = wl
del mxd
DavidPike
ah I think I made a silly error, I'm unable to test this.
side note - why are you using mxd.save() and why have you got outFile variable created then overwritten 2 lines later?
import arcpy, os
whereList = []
print df.name
    for row in cursor:
        for item in row:
    mxd.save()
    df.scale *= 1.5
    for elm in arcpy.mapping.ListLayoutElements(mxd, "TEXT_ELEMENT", "title"):
        if elm.name == "title":
           elm.text = wl
del mxd
MahmoudHegazy
the code worked
MahmoudHegazy
firstly i would like to thank a lot  for your effort
i made in mxd save and overwrite beacouse the code write from the field have char like )(.\ and the code run out while was running so
saving mxd to know the last extent while the cod was run
what iam thinking now to put the function .strip() int outfile name to clear char like this ()\|?
DavidPike
.strip() would only remove trailing and leading stuff.  Probably best to do something like this:
name = ''
for char in wl:
  if char.isalpha():
    name+=char
outFile = imgLocation + '\\' + name + '.pdf'
