export map layout with loop definition query
10078
22
09-15-2021 02:08 AM
MahmoudHegazy
i would like to complete my script to zoom to layer per definition and export pdf but the script give me bugs when it export pdf and not zooming can any help me
import arcpy, os
mxd = arcpy.mapping.MapDocument("CURRENT")
df = arcpy.mapping.ListDataFrames(mxd)[0]
layerName = arcpy.GetParameterAsText(0)
fieldName = arcpy.GetParameterAsText(1)
imgLocation = arcpy.GetParameterAsText(2)
whereList = []
layerFile = arcpy.mapping.Layer(layerName)
layerFile.definitionQuery = ""
print df.name
with arcpy.da.SearchCursor(layerName, fieldName) as cursor:
for row in cursor:
for item in row:
whereList.append(item)
for wl in whereList:
layerFile.definitionQuery = fieldName + "= '" + wl + "'"
df = layerFile.getExtent()
df.extent = outFile
outFile = imgLocation + "\\" + wl + ".pdf"
arcpy.mapping.ExportToPDF(mxd, outFile)
del mxd
Tags (4)
MahmoudHegazy
how can i set camera object extent instead of get extent
import arcpy, os
aprx = arcpy.mp.ArcGISProject("CURRENT")
df = aprx.listMaps()[0]
whereList = []
layerFile = df.listLayers(layerName)[0]
print ((df.name))
    for row in cursor:
        for item in row:
    #new_extent = layerFile.getExtent()
    new_extent = df.camera.setExtent(df.getLayerExtent(layerFile, False, True))
    df.extent = new_extent
    df.scale *= 1.5
    for elm in arcpy.mp.ListLayoutElements(mxd, "TEXT_ELEMENT", "title"):
        if elm.name == "title":
           elm.text = wl
    name = ''
    for char in wl:
        if char.isalpha():
            name+=char
    outFile = imgLocation + "\\" + name  + ".pdf"
    arcpy.mp.ExportToPDF(mxd, outFile, "PAGE_LAYOUT")
del aprx
MahmoudHegazy
it worked, thanks so much
i made a post as you said to make anyone help me to convert the script to arcgis pro becouse of dynamic table
in the linke blow:
https://community.esri.com/t5/python-questions/convert-script-python-work-with-quot-export-layout/m-...
MahmoudHegazy
error in arcgis pro
 invalid syntax line 31
import arcpy, os
whereList = []
print ((df.name))
    for row in cursor:
        for item in row:
    lay = aprx.listLayouts("Layout")
    mf = lay.listElements("Layers Map Frame","New Data Frame Map Frame")
    new_extent = mf.camera.setExtent(mf.getLayerExtent(layerFile, False, True)
    #df.extent = new_extent
    #df.scale *= 1.5
    for lyt in aprx.listLayouts("Layout"):
        for elm in lyt.listElements("TEXT_ELEMENT"):
            if elm.name == "Text":
                elm.text = wl
