Introducing the GIS Enterprise Reporter
56030
32
04-05-2022 11:57 AM
DannyKrouk
56 32 56K
A common challenge in administering an ArcGIS Enterprise system is the need document and/or otherwise communicate its design and configuration.
Typically, this is done by someone creating one or more diagrams.  These diagrams sometimes have errors and/or omissions.  And, they easily lose their relevance as the system changes.  The underlying challenge is that the documentation of the system is not generated by the system itself, it reflects the understanding of one person at one moment in time.
GIS Enterprise Reporter is designed to help address this challenge by automating the creation of documentation artifacts.  Point the tool at your ArcGIS Enterprise, with administrative credentials, and it will generate documentation that includes:
  1. A logical diagram
  2. Listings of administrative/configuration settings (from the REST admin API's)
  3. Listings of machine resources and installed software (for the machines running the software in the ArcGIS Enterprise system)
  4. ArcGIS Server service inventories (inclusive of workspaces and datasets)
  5. Portal content inventory
  6. Portal users and groups inventory
  7. And, information about TLS/SSL certificates (including certificate expirations, required trust chains, etc.)
The documentation is output in Microsoft Excel format, making it easy to share, analyze, and mark-up.
This tool is intended to be used by ArcGIS Enterprise administrators to understand and document their system deployments.  It works best if it is run under a credential that is also a local machine administrator, but that is not required.
Please note that this tool has been created to support Esri Professional Services consulting practices.  As such, it is not supported by Esri Technical Support.  All of the requests issued by the tool are supported ArcGIS REST API operations.
You can download the tool here: https://github.com/EsriPS/gisenterprisereporter.  The .zip contains both the executable and documentation.  The executable is a ".Net Core" executable that should run on any contemporary Windows operating system.
The executable is signed with a certificate that is not issued by a public certificate authority.  So, you may get warnings (or limits) from your operating system related to that.  If so, please follow the guidelines of your organization and the privileges extended to you by working with the appropriate IT security authorities, importing the certificate into a your trust repository, or using elevated privileges to execute the tool.
Please be in contact with me, Danny Krouk ([email protected]) with questions or enhancement ideas.
This article is intended to be the first in a short series of articles about GIS Enterprise Reporter.  Future articles will address topics such as running the tool, interpreting its output, and creating useful analyses from the output.
Next Series Article: Running the GIS Enterprise Reporter, Tips & Tricks
32 Comments
vbort_ef
Good morning, I find this tool essential for building an exhaustive inventory of an ArcGIS Enterprise organization. It is a wealth of information for customers but also to consolidate our relationship with them. For example, in the context of support cases, migration, version upgrade or even implementation of new uses of an ArcGIS platform. I really hope that it will be maintained, why even packaged in a solution (synchronization, data published in services on portal, synthesis with ArcGIS Dashboard). But I'm definitely dreaming. Thank you again, this is very useful for me to follow the uses of my customers. Best wishes
DannyKrouk
@vbort_ef  Thank you very much for the kind words.  I have no plans to stop maintaining the tool ... we use it in Esri Professional Services.  If you have ideas for improvement, or come across defects, please let me know. 🙂
cboyerTucson
Hello! Thank you so much for providing this very powerful tool, we have used it quite a lot. I have a (hopefully) simple question: our organization is attempting to track down what EGDB connections were used when the map services on our stand-alone ArcGIS Server sites were published. I know I can find this information in the D:\arcgisserver\directories\arcgissystem\arcgisinput\[Folder]\[xyz.MapServer]\extracted\manifest.xml file, however, I am curious if Enterprise Reporter is capable of collecting all of this information into a single source? I have briefly examined its outputs and I definitely see registered data stores, but I have been unable to identify specific service database connections.
Any advice is very appreciated 🙂  Thank you, kindly.
DannyKrouk
@cboyerTucson  Thanks for the kind words.
You might be looking for:
Which gives you this kind of thing:
If that's not quite what you're after, perhaps you can tell me what is missing relative to your interests?
Thanks 🙂
cboyerTucson
Dearest @DannyKrouk , you have just saved me HOURS and HOURS of work. If I could bake you a box of cookies, you'd best believe I would. Thank you so so much for your lightning quick and immeasurably helpful reply and work on this incredible product. 🙏
DannyKrouk
@cboyerTucson  Ha!  Thanks.  Virtual cookies are almost as good as real ones! 😉
SteveMcCarthy
@DannyKrouk Has there been any thought as to adding this amazing tool to ArcGIS Monitor?  It would be a great fit based on the permissions required to run ArcGIS Monitor.  The ArcGIS Monitor Excel Report tool and the would Enterprise Reporting Tool really compliment each other.
Great job on this tool!
Thank you,
Steve
DannyKrouk
@SteveMcCarthy - Thanks for the idea (and the kind sentiment).  I have worked with the ArcGIS Monitor team to help them plan their functionality roadmap as it relates to eGDBs.  I had built extensions for the "classic" ArcGIS Monitor edition.  I believe their design intent was to include much of what those extensions did in the core product.  I have to confess that I have not followed what has come to fruition.  But, it does seem like there has been interest and intent.  I am sure that, if you have specific ideas, that they would appreciate hearing them. 🙂
Daniel_C
New Explorer
@DannyKrouk  This tool is amazing and has saved me a ton of time tracking dependencies on services/databases when we migrated our org to a new server stack last year that had a totally revamped architecture.
I would like to use the output from this this as the source data for some Power BI dashboarding that we are looking to develop to give an admin perspective of our Prod/Test/AGOL environments.  The part I'm trying to work though is figuring out how to set this up as a scheduled task.  I have been looking at Python subprocess and I can open the program but am struggling with the arguments.  Do you have any advice for scheduling Enterprise Reported to run on an interval.
DannyKrouk
@Daniel_C  Thank you for the kind words!
There is a separate executable called "er.exe" which can be used for scheduled execution of GIS Enterprise Reporter.  That's kind of an historical accident.  The code called by the executable is the same as that which gets called by the GUI.
Section #6 in the Word document that comes with the tool discusses how to use the command-line interface.  Essentially, you put your parameters in a json file and provide the file as an argument to the command-line.  Here's a partial screen capture from that section of the doc:
Please note that AsynchronousExecution is no longer supported (i.e. the parameter should either be absent or the value should be "false" if it is present) ... another historical accident (sorry).
Does this help?
Daniel_C
New Explorer
@DannyKrouk
That is exactly what I needed.  Appreciate the info!
dgiersz_cuyahoga
Will there be a Windows 11 version released? I get a 'This app can't run on your PC' warning when starting the executable. I am using Windows 11 Enterprise.
***Edit*** My bad, I think my exe was corrupted somehow. Downloading the latest version corrected my issue.  Keep up the great work!
DannyKrouk
@dgiersz_cuyahoga Thanks for the update.  The app should run on Win11.  If you continue to have problems after your re-download, please reach out *with screen captures* ... here or via email ([email protected]).
AkmalJasman
I've run the enterprise reporter in purpose to understand our customer environment deployment. While we analyze the report, we find out one of the repositories categorized as "queue store" just below the relational store. Is queue store being another name for graph store?
DannyKrouk
Hello @AkmalJasman - I believe queue store is a "quiet default" at a certain release of ArcGIS Enterprise (in the Data Store).  It is not another name for the Graph Store (you can add a Graph Store also).  I've never seen an option to configure it (or to leave it out of the configuration).  I don't know what it does.  And, I've not seen any documentation that explains.  Sorry that I cannot offer any clarity.  To me, it is just a fact reported by the API.
ShaunGibbins
Hi @DannyKrouk
Is it possible to determine which registered datastore is in use by each service? I know I can get which database is in use from the manifest but its the datastore name I am after.
I have inherited a bit of mess to unravel where datastores have been registered with different names but reference the same database, so I want to identify services that are using the spurious datastores, republish them with the correct datastore then get rid of the mess once there are no services using them.
DannyKrouk
@ShaunGibbins  -  You may be interested in the "Services datasets" sheet in the Admin Excel.  Each row is a unique combination of service, workspace, and dataset.  So, you can see not just which repositories are referenced by a service, but also which datasets.  "Manifest workspace info" also reports the repositories referenced by services (slightly different details).  The question of *registered* repository is much trickier.  It is not always possible to relate the repositories used by services to those which are registered (for a variety of reasons).  But, "Registered Workspace Cross References" attempts to do that.
ShaunGibbins
Thanks Danny
I will give it a try, thanks for your help.
TracyMoy
We just used the tool on our system. Thank you so much! Awesome tool!
DannyKrouk
@TracyMoy  I'm glad the tool is useful for you.  Thank you saying so. 🙂
LHo
Hi Danny
Thanks for providing this tool!
Just wondering are you aware of any tool that can convert these excel output files into dummy arcgis python api objects? This way we could reuse python using arcgis code without having to rely on https.
DannyKrouk
@LHo If you are asking about creating JSON objects, this is what the "migrator artifacts" button does.  Be careful what you ask for ... it writes a lot of files.
LHo
Hi @DannyKrouk
I was more thinking a kind of adaptor or ingestion function to create at least a subset of the objects, properties, methods etc available in the arcgis python api.
For example, this works when we connect directly to a portal via https.
import arcgis
gis = arcgis.GIS(url, u, p)
user = gis.users.get(username)
groups = user.groups
But we have a lot of the info in the GIS Reporter output excel files / artifacts, and we could potentially use a lot of the same code if we create similar objects. Example
import arcgis_from_reporter as repgis
gis = repgis.GIS(admin_excel_file, content_excel_file)
DannyKrouk
@LHo I see.  So, you don't want *objects*, you want *classes*.  I have no plans to generate classes from GIS Enterprise Reporter.  Sorry.
DeanMoiler
Thanks for creating this tool @DannyKrouk, I make use of it quite a bit and it's brilliant!
DannyKrouk
@DeanMoiler Thank you for the kind words.  If you have enhancement ideas (or defects), please be in touch.
iprameshwari
Hi @DannyKrouk! thanks for creating this awesome tool! it helped me a lot in doing assessment contents of our organization's Portal 😀
I've been searching thoroughly but I haven't found any columns in Portal Content and Server Admin's excel that represent the serviceLayerID (like MapServer/3). Is there anything like so or probably it's going to be improved in the future?
DannyKrouk_ps
@iprameshwari  - Thank you for the kind words.  For reasons that are not known to me, ArcGIS Server puts the layer id's in the REST services API but not the REST admin API.  This tool only accesses the admin API.  So, unless the product developers put the layer id's in the admin API, then it would not be in the foreseeable future of this tool.  Sorry about that. - Danny
RickeyFight
@DannyKrouk
Thank you for this tool. I ran it and created a simple local html that allows for the search for layers and webapp titles. That way others in our dept can look up layers or webapps if they need service information.
DannyKrouk
I'm glad the tool is useful for you @RickeyFight  🙂
PrayagShah
Thank you so much, Danny — this is amazing! I had already deployed the Enterprise environment and kept all the documentation notes with me, but this tool still provided extra information that I had forgotten (haha). It really helped me a lot. Thanks again for creating it!
DannyKrouk
Thanks for the kind words @PrayagShah.  I'm glad the tool is helpful.  If you are interested, there is a separate tool, officially supported by Esri, which is catching up to the features of Enterprise Reporter.  I hope that, someday soon, it will eliminate the need for Enterprise Reporter (which is not supported by Esri).  This is the Configuration Reporter overview: https://www.esri.com/arcgis-blog/products/arcgis-enterprise/administration/introducing-the-configura....
