Implementing ArcGIS Blog - Page 2
Latest Activity
(184 Posts)
AaronLopez
Although you are probably familiar with using System Log Parser (SLP) to read logs and help you quantify your ArcGIS Enterprise usage, there is a relatively new feature in this popular, free utility that can make the effort easier and the analysis more powerful.
The new feature, commonly referred to as the Optimized report in System Log Parser, allows you perform log queries of much larger time spans. In addition, it can perform the parsing faster and with tremendous memory savings over the classic analysis types (e.g. Simple, WithOverviewCharts and Complete).
The Optimized option still generates a spreadsheet-based report statistically summarizing the collected log information into key time focused categories.
Read more...
more
4 7 9,992
NoahMayer
The Architecture Practice team in Professional Services have been writing articles to assist the community to plan, design and deploy ArcGIS Enterprise. This purpose of this page is to be a single resource to all these blogs and will be updated as new posts are created.
Read more...
more
20 1 5,854
DannyKrouk
GIS Enterprise Reporter allows you to clearly document existing deployments of ArcGIS Enterprise (Portal for ArcGIS, federated ArcGIS Server Sites, ArcGIS Data Stores, etc.).  You can use this tool to document and compare deployments in different environments, understand changes over time, etc.
Please note that this tool is not a product of Esri.  It is a tool produced by an employee of Esri and made broadly available in the hopes that it will be useful.  It is provided "as is".
Read more...
more
55 28 36.2K
AaronLopez
Apache JMeter is a great load testing tool, but it's a fantastic automation framework too! This Article focuses on using JMeter to call the ArcGIS REST API in order to carry out user management tasks that would be tedious for large numbers of members.
Table Of Contents
  • Administration Automation with Apache JMeter
  • The User Administration Test Plans
    • The CSV Data Set Config of Users
    • The Text File List of Users
    • Administrator Login
  • Add a New User (portal_users_add1)
  • Add a New User (portal_users_add2)
  • Add a New User (portal_users_add3)
  • Set the Security Question/Answer for New Users (portal_users_update_profile1)
  • Disable a User (portal_users_disable1)
  • Enable a User (portal_users_enable1)
  • The Thread Group Configuration
  • Test Execution
  • Validating the Test Plans
    • Troubleshooting a Command-line Test Execution
  • Final Thoughts
    • A Quick Word on Using Multiple Threads
    • A Quick Word on Deleting Users
Read more...
more
2 5 2,281
AaronLopez
A geoprocessing (GP) services is essentially a resource that is setup to perform or automate any ArcGIS Enterprise task. The purpose of this tool could be something that works on a feature class or table and creates an output dataset. The work performed could be to take in a set of inputs and generate a buffer or project to another spatial reference.
They take the form of being either synchronous or asynchronous. This is known as the execution mode.
Synchronous geoprocessing services are ideal for small jobs where the required computation to complete the task is very quick (e.g. just a few seconds). In this case, all the requests involved in the process are short-lived and load testing such a service would be straight-forward: construct a test to send the requests as they (sequentially) appear when interacting with the service. Once the job request is submitted, the response returns as soon as it has completed.
Asynchronous geoprocessing services on the other hand, have more moving parts. Since the task could be very long running, once the job has been submitted, its up to the user (the tester) to periodically check on the status of job with a separate request. Status state checking logic inside a loop introduces complexity to the test.
This article can be used as a guide for load testing an Asynchronous GP service. While it is specific to the "Summarizing Invasive Species" example, the majority of the test and its logic can be applied to other geoprocessing services.
Table Of Contents
  • Why Test a Asynchronous Geoprocessing Service?
  • Asynchronous Geoprocessing Service Testing Challenges
  • How to Test an Asynchronous Geoprocessing Service?
    • The "Summarize Invasive Species" Geoprocessing Model and Dataset
    • Test Data Generation
  • The Asynchronous Geoprocessing Service Test Plan
    • Components of the Test Plan
      • SubmitJob
      • CSV Data Set Config
      • InitialJobStatus
      • LoopJobStatus
      • WhileLoop
        • JobStatusCheck
        • ResponseAssertion
        • SleepWhileLoop
        • IfWhileLoopMax
      • IfJobSucceeded
      • DownloadOutput
      • IfTestIterationMax
    • Transactions
    • Requests
  • Test Execution
  • JMeter Report
    • Throughput Curves
    • Performance Curves
  • Final Thoughts
    • A Quick Word on Sizing
    • A Quick Word on Instances
    • A Quick Word on the Location of the arcgisjobs Folder
Read more...
more
0 3 2,468
AaronLopez
Cached map services are a popular and recommended way to provide a fast performing presentation of static data. When map services are cached, the server draws the data at a set of map scale levels you define and saves the images. Then, as the server received requests for the map, it is much quicker (and requires less CPU resources) to retrieve the pre-created cached images than it is to dynamically draw the map again. This is the benefit of cached map services.
Generally speaking, cached map services can support simultaneous requests from many users. Such services can scale well. Despite this well known performance characteristic, it is still a common requirement to load test a cached map service to see first-hand how it behaves and scales on the hardware of a particular ArcGIS Enterprise deployment.
This Article contains a walk-through for load testing a cached map service with an Apache JMeter Test Plan. The examples use a public accessible dataset. Using datasets in Coordinate Systems other than WGS 1984 Web Mercator Auxiliary_Sphere (WKID: 3857) should work, but the generated test data will be based on a WKID of 3857.
Table Of Contents
  • Why Test a Cached Map Service?
  • Cached Map Service Testing Challenges
  • How to Test a Cached Map Service?
    • The Natural Earth Dataset
      • The Generate Bounding Boxes (Precision) Tool
      • Visualizing the Generated Data in ArcGIS Pro
      • Visualizing the Generated Data in a Text Editor
  • The Cached Map Service Test Plan
      • Levels Of Detail List Logic
      • GetMapTile Logic
      • Cache Tile Loop and Path Population
        • Loop Controller
        • Counter
        • JSR223 Sampler
        • HTTP Request
    • Transactions
    • Requests
  • Test Execution
  • JMeter Report
    • Throughput Curve
    • Performance Curve
  • Final Thoughts
    • Additional Items Worth Mentioning
    • Assumptions and Constraints
Read more...
more
3 7 3,540
AaronLopez
Network Analyst has always been in-demand capability of ArcGIS Enterprise as it provides popular problem solving analysis types such as Route, Service Area, Closest Facility and Origin-Destination Cost Matrix.
This Article contains a walk-through for load testing a route solver service (map-based service) with an Apache JMeter Test Plan. It uses a public accessible dataset in the examples for the data generation and test configuration process. However, the testing procedure should work when using any valid network dataset. This Article assumes you are familiar with Apache JMeter and some of the Test Plan strategies we have been using in other discussions.
Table Of Contents
  • Network Analyst Route
  • Load Testing a Network Analyst Route Service
  • How to Test a Network Analyst Route Service?
    • Network Analyst ArcGIS Pro Tutorial Data
      • Making the Tools Available from ArcGIS Pro
      • Launch the Generate Data (Solve Route) Tool
      • The Generate Data (Solve Route) Tool Inputs
      • Spatially Visualize the Generated Points
  • The Route Solver Test Plan
    • HTTP Request
    • Transactions
    • Requests
  • Test Execution
  • JMeter Report
    • Throughput Curve
  • Final Thoughts
Read more...
more
0 0 1,699
AaronLopez
One of the most popular functions for consuming resources from an ArcGIS Enterprise Site is through hosted feature services. Their data source is managed by ArcGIS, the scale very well and visualization is performed on the client.
This Article contains a walk-through for load testing a hosted feature layer service with an Apache JMeter Test Plan. It uses a public accessible dataset in the examples for the data generation and test configuration process. However, any source using a Projected Coordinate System of WGS 1984 Web Mercator Auxiliary_Sphere (WKID: 3857) should also work. The Article assumes you are familiar with Apache JMeter and some of the Test Plan strategies we have been using in other discussions.
Table Of Contents
  • Why Test a Hosted Feature Service?
  • Hosted Feature Service Testing Challenges
  • How to Test a Hosted Feature Service?
    • The USGS Motor Vehicle Use Roads Dataset
      • Select an Area of Interest
      • Run the Generate Query Extents Tool
      • Adjust the Inputs for the Generate Query Extents Tool
      • Validating the Generated Test Data
  • The Hosted Feature Service Query Test Plan
      • Data Reader Logic
      • Operation ID Selection Logic
      • Operation Loop and Parameter Population
      • HTTP Request
    • Transactions
    • Requests
  • Test Execution
  • JMeter Report
    • Throughput Curves
  • Final Thoughts
Read more...
more
2 11 5,461
AaronLopez
While we have talked about constructing JMeter tests and provided several samples, we have not yet shared how to generate test data, which is half the battle of creating a good test. However, I am excited to talk about a set of load testing tools for ArcGIS Pro that has recently been released that does exactly that.
This free utility is available now and called: Load Testing Tools.
One of my favorite tools in this set is "Generate Bounding Boxes" which can quickly and easily generate bounding boxes by the either the map's current extent or a selected polygon...very powerful. The generated data can be visually validated via separate feature classes (one for each map scale) and plugged right into an Apache JMeter Test Plan (via CSV files that are also created).
Table Of Contents
  • What is Test Data?
  • Tools for Creating Custom Load Data
  • Creating Custom Test Data
    • Using A Polygon to Outline the Area of Interest
    • Generate Bounding Boxes Tool Inputs
    • Visualizing the Generated Data from the Individual Feature Classes
    • Visualizing the Generated Data from the Individual CSV Files
  • Using the Generated Data in an Apache JMeter Test Plan
Read more...
more
5 2 5,633
AaronLopez
The load testing of ArcGIS Enterprise can be carried out using a variety of different tools like: JMeter, LoadRunner or Silk Performer. While all test tools essentially perform the same task of applying pressure to a particular resource and measuring its impact, having a listing of the meanings to common phrases can help ensure testers and analysts are on the same page.
This resource provides insight into some testing fundamentals that are mentioned in other Community Articles about performance and load testing of ArcGIS Enterprise. The vocabulary definitions are listed from a chronological point of view. It all starts with a request so this is the first item discussed.
Read more...
more
0 1 3,071
127 Subscribers
