Ahhhh based on your last image, it is clear... it failed because it was being run in 2009
Dear sir if the input file format is '' .lyr '', is there any problem sir.
yes...layer files have no table, they are associated with data, you have to use the shapefile or featureclass
sometimes, when i gave layer file as input, it work
Dear sir
i couldn't understand ''being run in 2009'', what is mean by 2009.
look at your results window and the run date wed may 13 ....2009
some temporal issues with your configuration?
Dear sir
i am sharing a link, from which i have downloaded glacier boundary
shape file, you please check what is the problem with this data.
i amworking on Himalaya part only.
http://glims.org/download/
