ClipLayer - The toolbox file was not found (ArcGIS Pro 2.9.0)
4066
5
12-20-2021 07:51 AM
ArchanaKC
I am trying to access the ClipLayer (Geoanalytics) tool using arcpy in my script to extract vector layers (polygons) that overlays grids (one by one) and save them as a new .shp. But I am getting the following error :
OSError: The toolbox file https://geoanalytics.arcgis.com/arcgis;services/GeoAnalyticsTools;UseSSOIdentityIfPortalOwned was not found.
Failed to execute (ClipLayer).
I checked the C:\Program Files\ArcGIS\Pro\Resources\ArcToolBox\toolboxes\GeoAnalytics Tools.tbx\ClipLayer.tool folder and content file, link file, resource script are available and I can run the tool successfully within ArcGIS Pro but since I have thousands of grids it is impossible to do it mnually.
Any help or way around would be much appreciated. Thank you for your time.
2 Solutions
JayantaPoddar
MVP Alum
Could you use Pairwise Clip (Analysis) instead? Check the Python code sample in the link.
Think Location
ArchanaKC
Thank you so much. Yes, I used it, and it's working fine.
Many thanks for your time.
DanPatterson
server or desktop?  Your license level and is it enabled for you?
GeoAnalytics Server toolbox licensing—ArcGIS Pro | Documentation
GeoAnalytics Desktop toolbox licensing—ArcGIS Pro | Documentation
... sort of retired...
ArchanaKC
Thank you for your reply. It's on desktop, I have an advanced license and the clipLayers is added. I can run it within ArcGIS Pro 2.9.0 toolbox and run it but could not get any success with arcpy.
For now, I used PairwiseClip(Analysis ) as suggested by Mr. Jayanta Poddar below and it works.
JayantaPoddar
MVP Alum
Think Location
ArchanaKC
Merce_UCR
Hello I have the same issue when we trying to run de Random Forest Based. I solve the issue with this!
