Experience Builder Tips and Tricks - Page 8
Latest Activity
(77 Posts)
DavidDas__GISP
This series of videos presented by GISman Lee will show how to develop a customised hierarchy-layer widgets in new ArcGIS Experience Builder with React.js, ArcGIS Javascript API & Reactstrap, as well as how to deploy Customised ArcGIS Experience Builder App on ArcGIS Enterprise.
Let's start moving from the old ArcGIS Webapp Builder to the new esri product. Initially 3 parts in total, maybe more in future.
https://www.youtube.com/watch?v=A-D0wAD1jUA
more
3 0 691
DavidDas__GISP
This YouTube video tutorial by GISman Lee presents an easy way to implement the communication among multiple customized widgets in ArcGIS Experience Builder.
With this method, you don't have to follow the complex ways of doing so as written in the Esri ArcGIS Experience Builder official website.
The method here is to combine the in-built Redux of ArcGIS Experience Builder with the ReactJS Life Cycle Functions, to establish a "pulling" style of message transactions.
https://www.youtube.com/watch?v=gQAqoasLkgY
more
4 2 1,083
DavidDas__GISP
Here is a comprehensive tutorial for absolute beginners on ArcGIS Experience Builder Developer Edition 1.12.
https://daviddas2.github.io/exb/
This app is mobile friendly. It collapses gracefully to fit a Tablet or Smartphone in portrait and landscape mode.
No programming is necessary. The two custom widgets for Google Earth and Pictometry come preconfigured.
The first 3 parts of this Tutorial can be done using the ArcGIS Online Edition of the Experience Builder.
more
7 0 2,296
JeffreyThompson2
MVP Frequent Contributor
This guide is copied from a post by @TonghuiMinghttps://community.esri.com/t5/arcgis-experience-builder-questions/overwrite-default-map-filter/m-p/1...
The first option is that you can configure a filter widget with clauses like the following - one clause with a solid none case, like ("OBJECTID=-1"), and not ask for values; then add other clauses that ask for values (they must not contain preset values, being all empty to make it work). Remember to set the logic operator to "OR":
Last but not least, you need to turn on the option "Apply this filter automatically". In this way, you will have the following behavior which starts with none on the map and filter by the desired/input values.
The second is pretty much the same but could be a little more straightforward - add a single filter item to do the above configurations, with only that special clause & turned on automatically. In other filter items, add the criteria for your cases. You can use OR/AND depending on how you want your users to experience:
Additional Tip: If you want to hide something in a feature layer completely from the user, you can set a filter in your webmap. Users in this example will never see a park that without the DevelopmentClass of Developed.
more
5 3 1,045
JeffreyThompson2
To change the icon displayed for a widget in a Widget Controller, simply click the icon in the Settings panel. You can upload your own icon with the plus sign at the bottom of this window. The box (black by default) in the lower right lets you pick the icon's color.
Rename titles by clicking the title of the widget in the settings panel.
Similar options are available for renaming or changing icons for sections and pages. (Just click on names and icons. You'll find them.)
more
4 0 1,175
JeffreyThompson2
ESRI documentation is only a click away.
Read more...
more
2 0 334
JeffreyThompson2
A place for Experience Builder designers to share guides, tips, tricks and easily overlooked stuff, so we can all make better Experiences with fewer headaches.
Read more...
more
21 0 4,592
225 Subscribers
