Elevation Data Questions
Latest Activity
Sort/Filter :
POST
Hello everyone,I created a raster with the Topo to Raster tool. for this I used layers of points and lines with eleva...
AntonioMoniz
by AntonioMoniz Occasional Contributor
in Elevation Data Questions Last Updated 10-23-2020
0 3
POST
Using Pro it is possivle to create an elevation profile for a feature; however this can only be exported as an image....
JamesGoodyear
by JamesGoodyear New Contributor
in Elevation Data Questions Last Updated 02-18-2022
3 1
POST
I have a raster showing the topography of  an area. I need to add 0.1 m to an area of the raster. I have tried making...
ArranClarke
by ArranClarke Emerging Contributor
in Elevation Data Questions Last Updated 08-07-2020
0 7
2923
POST
I have some GPS data with the elevation taken using the hybrid GEOID18. Can I covert the elevation values from GEOID1...
PatriciaCarbajales
by PatriciaCarbajales New Contributor
in Elevation Data Questions Last Updated 07-08-2020
0 0
POST
Hi i am completly new to this, i have set up a basic webscene , and now i want to add elevation profile to that map.b...
RahulSapkota
by RahulSapkota Emerging Contributor
in Elevation Data Questions Last Updated 06-22-2020
0 0
POST
I have two DEMs (geotif), one is of a larger area and the other of a smaller area located in the middle of the first ...
Anonymous User
by Anonymous User Not applicable
in Elevation Data Questions Last Updated 06-18-2020
1 0
POST
Hello!I am working on maybe an unusal project right now. I have downloaded a race route from my Strava account as a G...
JohnnyHarley
by JohnnyHarley Emerging Contributor
in Elevation Data Questions Last Updated 05-14-2020
0 1
POST
Hi, I am currently editing a layer and in doing so I am losing the ‘z’ values of various features. I do have a TIN mo...
AntonelloRizzo_Naudi
by AntonelloRizzo_Naudi Emerging Contributor
in Elevation Data Questions Last Updated 04-28-2020
0 0
POST
I have a USGSDEM file downloaded from NRCAN. It has a known geographic coordinate system (GCS_North_American_1983) so...
Myla-RaeBaldwin
by Myla-RaeBaldwin Emerging Contributor
in Elevation Data Questions Last Updated 09-15-2020
0 3
POST
Hello,If you were to take a certain elevation threshold (contour line) and select all area ABOVE that line, you might...
CoreyChin
by CoreyChin New Contributor
in Elevation Data Questions Last Updated 12-19-2019
0 2
POST
I have created a Hillshade effect and would like to use the Contours tool on the 3D Analyst toolbar to show me the Co...
SLouq
by SLouq MVP Alum MVP Alum
in Elevation Data Questions Last Updated 12-09-2019
0 2
POST
Team,The default or first option for any raster re-sampling / re-projection geoprocessing tools is "nearest neighbor"...
JoelSholtes
by JoelSholtes New Contributor
in Elevation Data Questions Last Updated 12-05-2019
0 0
POST
I have a Digital Elevation Model and polygon shapefile and I want to make an effect that polygons follow terrain stru...
SlobodanKomatina2
by SlobodanKomatina2 Emerging Contributor
in Elevation Data Questions Last Updated 11-30-2019
0 2
POST
Hi fellas,I have a line feature, also have a DEM, just want to extract the highest and lowest points of this line. I ...
Liliaaaaaa
by Liliaaaaaa Occasional Contributor
in Elevation Data Questions Last Updated 10-17-2019
0 6
5583
POST
6 Subscribers
