Drone2Map for Schools
2560
04-16-2021 11:32 AM
TomBaker
Drone2Map is now included in the Esri Schools Mapping Bundle (Advanced)!  Want to map those beautiful images captured by your drone?  Use Drone2Map.
Set-up
  1. Access and manage your Drone2Map licenses through your school’s ArcGIS Online account.
  2. Enable the license (just as you do with ArcGIS Pro) for each student account.  Click: Organization -> Members -> (click ellipses to right of user) -> Manage Add-On Licenses -> (under Applications) -> ArcGIS Drone2Map.
  3. While you're checking your account, make sure that any account downloading the software also has "Esri Access Enabled" using the menu under the ellipses.
  4. Download the Windows-only Drone2Map software. See the button link in the upper-right of the webpage at: https://doc.arcgis.com/en/drone2map/
  5. Install the software.
Learning the basics
 In terms of guidance on learning to use it, see
After working through these, you should be ready to go with your own projects.
About the Author
Geospatial technologies in K-12, higher education, teacher education, and informal learning. Esri Education Team
