While on the school's grounds I collected data simultaneously with three methods and two devices: (1) As a track using an app called RunKeeper on my smartphone (an iPhone 4 in my case), (2) As a track and waypoints using an app called Motion X GPS on my smartphone, (3) As a track and waypoints using my Garmin 76 GPS receiver. In order to keep my footing on the steep terrain, I simply held these devices in front of me; I did not hold them above my head or in any way enhance the reception. After the collection was completed, I emailed the smartphone data as GPX files to myself and uploaded them into
ArcGIS Online. I cabled the points from my GPS device to my computer using the
free Minnesota DNR GPS program and mapped them as a zipped shapefile. I saved the
results in ArcGIS Online as a web map.
Comparing smartphone and GPS tracks and waypoints.
As expected, the RunKeeper track, shown in pale blue, was highly generalized. RunKeeper is a fitness app that I use daily with excellent accuracy, but I suspect the generalization here occurred in the step when I downloaded the track to a GPX file and mapped the GPX. However, both the Motion X GPS track collected with the smartphone and the track collected with the GPS receiver were only 1 to 2 meters off from where the satellite image showed the trails to be. And keep in mind that this model of GPS is already a decade old; the chips in the newer models can even detect GPS signals inside certain types of buildings. In addition, my smartphone is nearly three years old.
Interestingly, at certain places, such as just west of where the popup graphic is located, the smartphone results were better, but south of the graphic, where I left the trail to photograph a bench, the GPS detected my side journey but not the smartphone. I also took photographs in the field with my smartphone and uploaded them to Picasaweb. I then accessed the photos in Picasaweb and captured the latitude-longitude coordinates, and used those coordinates to map them in ArcGIS Online. The photographs also were no more than 1 meter off of the location I had taken them according to the satellite image.
I was very pleased with the smartphone and GPS results, particularly because the school lies in steep and heavily forested terrain in the Colorado Rocky Mountains. If I achieved good results here, the results should be even better in flat terrain and with fewer trees. And while there are still some advantages for using GPS receivers in education, the smartphones are a viable technology for doing so, and they too offer advantages. I will expand on the advantages of both in future blog essays, and keep in mind that
smartphone location services can use GPS, cellular triangulation, and geo-wifi, or a combination thereof, and you as the user typically do not know which one(s) it is using at any particular moment. The takeaway here is that GPS and smartphones both do a fine job in terms of spatial accuracy. True, I wasn't mapping fiber optic cables, but for marking trees, bird's nests, trails, and a host of other items that educators and students want to map, they are quite suitable.
How do you use GPS receivers and smartphones in your educational work? How might you use this type of spatial accuracy comparison as part of your math, science, or geography-based curriculum?
