use a arcgis server service than a webmap id
4926
09-28-2014 05:06 AM
GopiParthasarathy
Hello All
I downloaded a ESRI ajavascript template from github... and I want to add a arcgis server web service instead of the webmap id
when I see the index.html file i see the code as : I need to skip the webmap and use my REST web service instead..
var  defaults = {
        //The ID for the map from ArcGIS.com
       webmap: "f5b13dbed07c46cdb783cf361833aa6b",  I WANT TO ADD my Service http://111.11.1.1/arcgis/services/test/mapserver
        //Modify this to point to your sharing service URL if you are using the portal
        sharingurl: "http://www.arcgis.com",//for example: "http://www.arcgis.com",
        //The id for the web mapping application item that contains configuration info - in most
        ////When editing you need to specify a proxyurl (see below) if the service is on a different domain
        //Specify a proxy url if you will be editing, using the elevation profile or have secure services or web maps that are not shared with everyone.
        proxyurl: "",
        //cases this will be null.
        appid: "",
        //set to true to display the title
        displaytitle: true,
        //Enter a title, if
Can some one help me out in this
Thanks
AlexeiB
Hi Gopi,
Try the following:
var myLayer = new esri.layers.ArcGISDynamicMapServiceLayer("http://1.2.3.4/arcgis/rest/services/MyServices/TestService/MapServer", { id: "myTestService", outFields: ["*"], visible: true });
myMap.addLayer(myLayer);
require(["esri/urlUtils"], function (urlUtils) {
     var myRule1 = urlUtils.addProxyRule({
          proxyUrl: "http://1.2.3.4/myMapProxy/proxy.ashx", // location of the proxy
          urlPrefix: "http://4.5.6.7/arcgis/rest/services/" // everything in your map that starts with this will be proxied
Hope this helps,
Alexei
GopiParthasarathy
Alexei many Thanks..
Clarification;
The program is using dojo and
var defaults = {.... } is all built and finally used in the code below..
    var app = new utilities.App(defaults, supportsLocalization);
so the code you typed in above - where will that fit in that defaults variable?
entire index.html that builds using the dojo is below... Can you point out where to add that snippet
dojo.require("utilities.App");
      dojo.require("dojo.on");
      dojo.require("templateConfig.commonConfig");
      var i18n;
      dojo.ready(function(){
        i18n = dojo.i18n.getLocalization("esriTemplate","template");
        var  defaults = {
        proxyurl: "http://110.74.199.12:7878/arcgis/rest/services/Tax_Map_Publish/MapServer",
        appid: "",
        displaytitle: true,
        //Enter a title, if no title is specified, the webmap's title is used.
        title: "",
        //Enter a description for the application. This description will appear in the left pane
        //if no description is entered the webmap description will be used.
        description: "",
        //specify an owner for the app - used by the print option. The default value will be the web map's owner
        owner: '',
        //Specify a color theme for the app. Valid options are gray,blue,purple,green and orange
        theme: 'blue',
        //Optional tools - set to false to hide the tool
        //set to false to hide the zoom slider on the map
        displayslider: true,
        displaymeasure: true,
        displaybasemaps: true,
        displayoverviewmap: true,
        displayeditor: true,
        displaylegend: true,
        displaysearch: true,
        displaylayerlist: true,
        displaybookmarks: true,
        displaydetails: true,
        displaytimeslider: true,
        displayprint: true,
        displayprintlegend: false,
        displayeditortoolbar: false,
        displaymapwidgets:false, //deprecated. After the June 2014 release set displayHome and displayLocate instead
        home: true,
        locate: true,
        //i18n.viewer.main.scaleBarUnits,
        //The elevation tool uses the  measurement tool to draw the lines. So if this is set
        //to true then displaymeasure needs to be true too. NOTE: THis tool is deprecated and should no
        //longer be used in the Basic Viewer. Use the new version of the template instead
        //https://github.com/Esri/elevation-profile-template
        displayelevation: false,
        //This option is used when the elevation chart is displayed to control what is displayed when users mouse over or touch the chart. When true, elevation gain/loss will be shown from the first location to the location under the cursor/finger.
        showelevationdifference: false,
        displayscalebar: true,
        displayshare: true,
        //Set to true to display the left panel on startup. The left panel can contain the legend, details and editor. Set to true to
        //hide left panel on initial startup. 2
        leftPanelVisibility: true,
        //If the webmap uses Bing Maps data, you will need to provide your Bing Maps Key
        bingmapskey: commonConfig.bingMapsKey,
        //Get the default map units
        units: commonConfig.units,
        //specify a group in ArcGIS.com that contains the basemaps to display in the basemap gallery
        //example: title:'ArcGIS Online Basemaps' , owner:esri
        basemapgroup: {
          title: null,
          owner: null
        //Enter the URL's to the geometry service, print task and geocode service.
        helperServices: commonConfig.helperServices,
        //Set the label in the nls file for your browsers language
        printlayouts: [{
          layout: 'Letter ANSI A Landscape',
          label: i18n.tools.print.layouts.label1,
          format: 'PDF'
          layout: 'Letter ANSI A Portrait',
          label: i18n.tools.print.layouts.label2,
          format: 'PDF'
          label: i18n.tools.print.layouts.label3,
          format: 'PNG32'
          label: i18n.tools.print.layouts.label4,
          format: 'PNG32'
        printlayout: false,
        printformat: "PNG32",
        //Specify the geocoder options. By default uses the geocoder widget with the default locators. If you specify a url value then that locator will be used.
        placefinder: {
          "url": "",
          "countryCode":"",
          "currentExtent":false,
          "placeholder": "",
          "singleLineFieldName":""
        //when true locations searches use the current map extent.
        searchextent: false,
        //Set link text and url parameters if you want to display clickable links in the upper right-corner
        //of the application.
        //ArcGIS.com. Enter link values for the link1 and link2 and text to add links. For example
        //url:'http://www.esri.com',text:'Esri'
        link1: {
          url: '',
          text: ''
        link2: {
          url: '',
          text: ''
        //specify the width of the panel that holds the editor, legend, details
        leftpanewidth: 228,
        //Restrict the map's extent to the initial extent of the web map. When true users
        //will not be able to pan/zoom outside the initial extent.
        constrainmapextent: false,
        //Provide an image and url for a logo that will be displayed as a clickable image
        //in the lower right corner of the map. If nothing is specified then the esri logo will appear.
        customlogo: {
          image: '',
          link: ''
        //embed = true means the margins will be collapsed to just include the map no title or links
        embed: false
        var supportsLocalization = true;
        dojo.on(app, "ready", function(config){
          initMap(config);
sapnas
You can use below code to replace webmap id with your custom map service
function add() {
          var webmap = {};
        webmap.item = {
          "title":"custom",
          "snippet": "custom",
          "extent":[[-70992265.886348, -32560951.057024], [70992265.886348, 32560951.057024]]
     webmap.itemData = {
          "operationalLayers": [{
            "url": "http://111.11.1.1/arcgis/services/test/mapserver ",
            "visibility": true,
            "opacity": 0.75,
            "title": "custom",
            "itemId": "204d94c9b1374de9a21574c9efa31164"
          "baseMap":
            "baseMapLayers": [{
              "opacity": 1,
              "visibility": true,
              "url": "http://services.arcgisonline.com/ArcGIS/rest/services/World_Terrain_Base/MapServer"
              "isReference": true,
              "opacity": 1,
              "visibility": true,
              "url": "http://services.arcgisonline.com/ArcGIS/rest/services/Reference/World_Reference_Overlay/MapServer"
            "title": "World_Terrain_Base"
          "version": "1.1"
       return webmap;
//Replace your webmapid with the function created above
        webmap: add(),//"f5b13dbed07c46cdb783cf361833aa6b",
AdamJoseph1
Hello Gopi,
You can also receive a webmap from cartoview in case you want a simple way to return your map. www.cartologic.com/cartoview here is how Cartoview
AdamJoseph1
the steps to create a webmapid with cartoview is listed here
Cartoview webmpID
