Mapping Holiday Races with the ArcGIS Static Maps Service
It’s the season of turkey trots and resolution races! A time when new and experienced runners alike sign up for 5Ks to support good causes and build community, or for marathons to challenge their endurance. For the running clubs, charities, and other organizations that plan, host, and sponsor these events, a website or…
Developer's Lounge: Building the ArcGIS Agentic Developer Toolkit
As AI continues to reshape how developers work, there’s a growing need for systems that optimize agentic workflows to ultimately improve developer efficiency. William Bohrmann, a product engineer on the Developer Experience team, is part of an amazing group at Esri that’s bringing that vision to life. They’ve built the…
🤖 What if AI coding agents had better ArcGIS context?
The new ArcGIS agentic developer toolkit helps developers build ArcGIS applications more efficiently and effectively with AI coding agents.Through MCP, agents can access ArcGIS developer documentation, and pre-built skills provide guidance for common mapping workflows. Developers can use the toolkit with AI coding agents…
Developer's Lounge: Creating a Documentation Site to Help Developers Navigate ArcGIS Hub
Andrew Turner is a Chief Technology Officer (CTO) at Esri, leading the team that builds and maintains ArcGIS Hub. In this Developer’s Lounge interview, Andrew introduces the new Hub documentation site for developers, and explains why he believes data discoverability and shareability are critical for developing platforms…
What Location Services are Available through ArcGIS Location Platform? Mapping, Search, Directions, and More
ArcGIS Location Platform enables developers to add geocoding, places, and data enrichment to your solution without a full GIS deployment. Consumption-based pricing means you only pay for what you use. See which service fits your use case!
slpk mesh format requirements in ArcGIS pro
Hi, I am trying to understand the cause of an issue occurring when using the ArcGIS Pro Generate Level Of Detail tool with slpk mesh assets generated by the pix4d pipeline. The mesh display correctly in ArcGIS but running the tool fails with an out-of-memory message (see screenshot). The failure doesn't produce for all…
Use custom output in a custom data feed
I've written a custom data feed for ArcGIS Server, and that works. Now, a new question has come up, and this is about additional output formats. E.g. the CDF should not only serve output as a FeatureServer, but OGC API Features as well. I see that there is already a plugin for KoopJS, so I was wondering if it is possible…
Develop for Good: Upgrading Emergency Support Systems with Location Services
Devastating flash floods and violent storms continue to occur around the world. In times of crisis, cities rely on emergency systems, not only to support major rescue efforts but also to keep the city running by strategically providing residents with ways to avoid floodwaters. This second article in the…
Best practices for integrating lightweight HTML5 / HLS video streaming layers into ArcGIS Maps SDK for JavaScript?
Hi Esri Developer Community, We are currently working on a modern web-based mapping application that displays real-time geospatial data feeds along with dynamic HLS video player overlays for custom media locations. While the core spatial rendering with ArcGIS Maps SDK for JavaScript works seamlessly, we are focusing on…
Best practices for handling asynchronous data loading and reducing client-side rendering overhead in custom web mapping apps
Hi Esri Developer Community, I am currently working on a custom web mapping application development workflow, focusing on how client-side scripts handle asynchronous data loading and heavy feature layer rendering. When dealing with frequent API requests or streaming large spatial datasets dynamically into a web…
How can I use GIS functions in a custom data feed
I am developing a custom data feed, and need to project some value from one coordinate system to another. I would think that such a method would be available by default, but I can't find anything. It seems overkill to have to include a separate library (say, proj4) when I'm already in a GIS platform, right?
Custom data feed with pagination
I am developing a custom data feed, that uses a 3rd party web API to get data. This web API supports pagination, so I can use the ArcGIS resultOffset and resultRecordCount parameters to limit the number of records I retrieve from the 3rd party. However, it looks like the CDF framework applies the resultOffset on the…
Develop for Good: Enabling Smarter Rescue Efforts with Location Services
Developers have a key role to play when it comes to rescue operations – saving lives should be a collective mission, with individuals across different roles in society lending a hand to causes that affect all of our communities, health, and the broader world. A recent blog discusses how ArcGIS Location Services empowers…
Curve information in "gdb_geomattr_data" column of PostgreSQL Geodatabase is lost when editing attributes
Anyone else run into this with traditional versioned editing in PostgreSQL? Curve geometry is lost when editing attributes with traditional versioning in ArcGIS Pro 3.4 and 3.7. We are using a PostgreSQL, SDE-enabled database using the PostGIS extension instead of st_geometry. When a shape is initially created in a…
SCF (ZIP3) KML File?
Newbie to this. I'm interested in mapping activity by the SCF areas (this is the first three characters of the U.S. ZIP). I am using (Mirco)Strategy, as it has ESRI maps built into it, but I think I need a custom kml file that would define the areas? Example: SCF of 727 is all of the ZIP's between 72701 and 72799. I want…
Timezone in the date() function-
I am building a new Arcade script for a Velocity Field Calculation --- Using the Date() functioon to retun the Epoc date. https://developers.arcgis.com/arcade/function-reference/date_functions/#date1 My issue is that the Source data seems to use the four-character time zone, and Date() does not seem to like this. I can…
Pick a PaaS that Supports Open Dev
Open-source flexibility or enterprise reliability? You shouldn't have to pick one. Learn how a location PaaS that supports open development gives you both, what to look for in a provider, and why developers switch to ArcGIS Location Platform for location services. Read the Blog
Problems sharing complex geoprocessing services to portal
I have a case where I would like to use the BatchTrace tool from the UtilityDataManagementSupport (UDMS) toolbox through the ArcGIS Rest API on my ArcGIS Enterprise server. I therefore would like to create a service-definition that I share as a geoprocessing service. I am going to use arcgis rest api and arcpy in…
Developer’s Lounge: Demystifying the Esri Developer Experience
“Where do I begin?” and “What tools are available for building my application?” are some of the most frequently asked questions by developers looking to leverage Esri’s developer technologies and tools. In this edition of the Developer’s Lounge series, Anita Kemp, Product Manager for Developer Technologies at Esri, tackles…
Introducing the New ArcGIS Static Map Service
Introducing the New ArcGIS Static Map Service The ArcGIS Static Maps service enables developers to create and easily embed map images into websites or applications. Customize the style of the map image as well as add points, polygons or routes. Static map images may provide a better user experience where interactive maps…
Programmatically login to portal using SSO
I'm writing a (.NET) application that accesses a portal, configured for SSO. I would like to login the current user without going through the login window at https://example.com/portal/sharing/oauth2/authorize , where you have the option to choose between AD login and ArcGIS login. Is this possible? I tried: var url =…
GeoAI Skills: 18 open Agent Skills for safer geospatial workflows
Hi Esri Community, I’m sharing the first public preview of GeoAI Skills, an open-source suite of 18 Agent Skills designed to help AI agents produce safer and more defensible geospatial workflows. The project focuses on silent spatial failures: errors that do not crash the workflow but can still make the result…
Developer’s Lounge: Empowering Users to Navigate Their Way Around Documentation with a New Ask AI Feature
Marcy Silverman, a senior software development engineer, is part of an incredible Developer Experience team at Esri that empowers users with all the information they need to get started. The team recently launched the new Ask AI feature — a powerful addition to Esri’s developer documentation that makes it easier than ever…
Follow Esri Developers on LinkedIn
Did you miss the exciting news? Esri Developers has a new LinkedIn page ➡️ https://www.linkedin.com/showcase/esri-developers/posts/ Esri Developers has a new page where you can get the latest on SDKs, APIs, ArcGIS Location Services, and tools that power real-world solutions. You can expect helpful tutorials, can’t miss…
Arcade expression help - "no value" in related table
Hi all, asking for help to edit this Arcade with a related table. I have a feature class related to a table in ArcGIS online where users will select from a list. There are 8 possible text fields to complete but often only 1 or 2 are populated. The rest should default to no value. Approximately 1000 data entry points have…
