ArcGIS Web AppBuilder Blog
Other Boards in This Place
Latest Activity
(48 Posts)
ShareUser
Esri Community Manager
When creating and updating features using Forms in the Editor widget, calculated expressions can be triggered to populate field values automatically.
The challenge: values for fields with calculated expressions cannot be edited or recalculated on demand, while editable fields do not support calculated expressions.
A workaround is proposed in this article.
Read more...
more
0 19 519
ShareUser
Learn how to replicate the Smart Editor widget (Web AppBuilder) functionality using Smart Forms (supported in Map Viewer, Experience Builder, Instant Apps, Field Maps).
Read more...
more
1 2 317
ShareUser
In Web AppBuilder, you can set up an interaction between the Group Filter widget and the Smart Editor widget to use the filtered value as a default value for attribute fields when you create new features. Learn how to recreate this functionality in Experience Builder using Smart Forms and Arcade.
Read more...
more
0 2 256
Jianxia
ArcGIS Web AppBuilder comes with ArcGIS Online, ArcGIS Enterprise, and the developer edition. ArcGIS Web AppBuilder is retiring, and we want to share the timelines and details with you.
Read more...
more
6 12 2,748
AlixVezina
Read more...
more
4 0 525
AlixVezina
The Info Summary widget – are you using it? Here's an opportunity to tell us what you need in the new generation of app builders!
Read more...
more
0 0 449
FasilTiru
With the June release of Business Analyst, there will be important change that will affect your existing custom infographics and reports in the Business Analyst Widget for Web AppBuilder.
Read more...
more
0 0 966
AlixVezina
The Smart Editor widget has seen many updates in the last few years. Learn more about new functionality, major enhancements, and the bugs fixed.
Read more...
more
0 7 3,971
BernSzukalski
Esri Frequent Contributor
National Telecommunications and Information Association (NTIA) has created a great app using ArcGIS Web AppBuilder that shows indicators of broadband need.
Read more...
more
0 0 798
ShelleySchott
Problem:
When a custom widget update/ redeployed which has previously been added to the Web AppBuilder gets corrupted, the custom widget ‘disappears’ from the Web App and the location of this widget also disappears. There is a gap and changing the widgets around does not fix this gap, it persists.
Cause:
Orphaned Portal IDs which don’t exist in Portal in the Json file of the Web App.
Read more...
more
6 6 2,433
185 Subscribers
