Utility Network Error Layers Not Created
2722
08-27-2020 02:45 PM
LoganSuhr_PSE
After creating a utility network for my electric network, I noticed that the typical point, line and polygon error layers don't seem to exist.  If I open a pro session and right-click the UN in my database and choose to 'Add to New Map' I only get the Dirty Areas polygons.
As expected, if I try to publish the UN without the error layers I get:
24099: The web layer being published cannot be consumed by ArcGIS Pro without all the Utility Network layers being present
I haven't recreated the UN yet, but I was hoping this community might have some insight before I do.  Thanks!
ArcGIS Pro 2.6
Enterprise 10.8.1
SQL Server 14.0.3335.7
PaulLeBlanc1
Utility Network version 4 does not have point, line, and polygon error tables; it only has the dirty area table.
As for that error during publishing, did you add the tables as well?
References:
Errors—ArcGIS Pro | Documentation
Dirty areas—ArcGIS Pro | Documentation
Utility network upgrade history—ArcGIS Pro | Documentation
PaulLeBlanc1
References:
LoganSuhr_PSE
Paul LeBlanc‌, thank you so much.  I guess I should have done my homework!
sjet1010
I have everything loaded, but I still get that error. Why is that?
