UN version 7, ArcGIS Pro 3.5.4 validation errors - a showstopper?
1298
17
11-04-2025 06:37 AM
DavidSDouglas
We're planning to upgrade in Production, and have done it in our Test environment. We're having big problems with validation  and can't risk an upgrade in production without a fix. Has anyone one else experienced similar issues? I'm asking before contacting support with the local ESRI partner - it's easier if some else can confirm this issue.
We upgraded from ArcGIS Pro 3.3 and ArcGIS Server 11.1     to 3.5.4 and 11.5
Also Utility Networks upgraded from version 5 to 7 (that took 20 hours)
.NET 8.0 is installed on servers (previously 6.0)
Some functions are running faster than before, faster even than the production environment which has not yet been upgraded - it has most resources. The servers are Windows Server 2022 Datacenter Azure Edition 21H2. The SQL Server database is Microsoft SQL Azure (RTM) - 12.0.2000.8
We have divided Denmark into 27 large polygons and validate these each night using a Python script:
GPextent= ('{} {} {} {}'.format(x1, y1, x2, y2))
arcpy.un.ValidateNetworkTopology(serviceUrlProd,GPextent)
After upgrading, this takes about 30 minutes to run, about half the previous time - also compared to production.
However, interactive validation in ArcGIS Pro using the Validate function on the Utility Network tab times out after 5 minutes even with the smallest extent (a few metres - which took only a few seconds before, and in production). If I attempt to validate again within the next few minutes I get:
Edit operation failed. Message: Unable to complete operation.
Details: Serialization lock in progress [[Microsoft][ODBC Driver 18 for SQL Server][SQL Server]Lock TimeoutX] [Serialization lock in progress - operation not allowed]
Eventually the lock is released - and validation will time out again on the next attempt. This has not been seen in the current production version,even if validation timed out after using too large an extent.
Using Validate Network Topology (Utility Network Tools), these small extents do validate - but it takes 30 minutes!
During editing, no dirty area appears after altering attributes. They do however appear if a feature is deleted.
DavidSDouglas
We succeeded in upgrading the Test environment at last, without any validation problems afterwards. The difference is that we removed versioning first - this took around 10 hours to run - and then enabled versioning again. It was much faster than a previous attempt as we temporary upgraded the Azure SQL service for the Test database to have 16 CPUs instead of 4. Every feature had probably been altered several times since we migrated 2 years ago (from one older UN version, and from Intergraph G/Technology after a company merger) - the original migration left many errors that have been corrected either by script or manually in the last 2 years. One table in the database, UN_8_EIDMAPPINGS has 230 million rows - it now has 9 million. After each step we tested ArcGIS - still able to validate. After reversioning, we upgraded geodatabase, tested, disabled network topology (much faster than before - I suspect versioning has caused us performance problems previously). Then Upgrade Dataset - it took 10 minutes - last time (before removing versioning) it took 20 hours! Even though we had quadrupled the CPUs, it must be the de-versioning that made the difference. One odd thing however - it took a while to work out we had to have the ArcGIS Server services running (they have to be stopped when disabling network topology or removing/re-establishing versioning), but the feature services using UN data had to be stopped on the portal. If the ArcGIS Server services were not running we got "ERROR 003320: The connected portal's federated servers do not meet the minimum supported release for the Utility Network - 10.7" - which was bizarre, as all servers were up-to-date. Anyway, after a long frustrating process, we now feel confident we can update to 3.5.5 and 11.5 in Production in the new year.
RobertKrisher
Have you opened a case with support yet?
DavidSDouglas
Not yet, but will do soon. In the last major support cases we have been asked to perform many time -consuming tests (creating new features, services, changing versioning, exporting to file geodatabase, recording video of screen etc, but there was no resolution of the the problem. That problem was that after running the Export to CAD tool, or Flip Line, ArcGIS Pro began to call a  feature service repeatedly for no evident reason, taking 20 - or sometimes even 200 seconds per call! The only solution was to exit and reenter ArcGIS. Then, when we upgraded to 3.5.4 in Test, we saw that the bug was no longer present. We can't have been the only customer to experience this, and I was hoping that by posting our current problem here, someone might recognise it (even though it's only a few weeks since 3.5.4 was released).
PierreloupDucroix
MVP Regular Contributor
Did you update the geodatabase version in addition to the UN version (using the Geodatabase Update tool)?
This resolved a significant performance issue we were experiencing in ArcGIS Pro (related to version posting, not network validation).
This could be a lead to investigate further.
CEO of MAGIS
DavidSDouglas
Yes, updating to the latest geodatabase version was a requirement for upgrading, now that objectid is 64 bit
Thomas_Brown
David,
Please provide the incident number. I'll make sure the issue is escalated and you will receive the proper support to narrow down this issue.
There are a few issues at play here... first to understand why your validates are so slow (which are likely leading to the serialization lock issue). Assumption is the validate you are performing is in a version?
Thank you.
Tom
DavidSDouglas
I installed the 3.5.5 update, which has some UN Validation  bug fixes - but that didn't help. However, I noticed we hadn't installed the ArcGIS Server 11.5 Feature Services Security Patch (from October) on the servers, so I did that, and it has helped the interactive validation problem - we can now validate, but only pretty small extents, otherwise it times out. We also are unable to run prune branch history - it failed after 36 hours working on UN_8_EID_MAPPINGS (no idea what that is, but there's 230 million rows in the database table). Almost all the other tables were pruned. We also tried to remove versioning and re-establish it, but there's still the same massive numbers of rows in UN_8_EID_MAPPINGS. We're now planning to start again with a fresh copy of the production database in Test, and document every step of the way. Can it validate using 3.3.0 before upgrading? I'm sure it can, but we will document it. Then we will try to remove versioning - if that doesn't succeed it's not a 3.5.5 / 11.5 issue. If it does, try validation again.  It may be faster to do the database upgrade again after removing versioning has massively lowered the number of rows in the tables, with added RAM and CPU just like in Production. That's so we can estimate how long it will take when we upgrade in Production (our control room is manned 24/7, so taking say 20 hours to upgrade the database is a major inconvenience).
DavidSDouglas
PierreloupDucroix
I am curious to learn more about the EIDMAPPINGS table, as it is growing considerably in our UN database.
CEO of MAGIS
RobertKrisher
@PierreloupDucroixthe most common cause of this is by frequent enabling/disabling of the network topology. the table maps every feature to its corresponding network element. every time you disable/enable the network topology we must delete and recreate all the mappings. The table is versioned, so if you are doing this frequently and not managing your conflicts and history than the table can become large.
