I've created the French field in my d_rename table to translate my UN electric database, the problem is that when I try to apply the asset package, I get these errors, knowing that I've modified these fields one by one (I've emptied their translation fields and I've put the real bypass) but it doesn't work.
Have you ever had this kind of problem? Do you have any help on how it could be caused?
The asset package has the following errors (48/48):
Item Field OID Value Message Level
0 CommunicationEdgeObject LENGTH NaN NaN This field name is reserved on some database platforms warning
1 CommunicationEdgeObject IGNORE NaN NaN This field name is reserved on some database platforms warning
2 CommunicationEdgeObject THIS_ATTRIBUTE_IS_NECESSARY_TO_ NaN NaN This field is too long for some database platforms warning
3 CommunicationEdgeObject DOCUMENTEDBY_REQUIREMENTSPECIFI NaN NaN This field is too long for some database platforms warning
4 CommunicationEdgeObject TENSIONADJUSTMENTBYTEMPERATURE NaN NaN This field is too long for some database platforms warning
5 CommunicationJunction IGNORE NaN NaN This field name is reserved on some database platforms warning
6 CommunicationLine LENGTH NaN NaN This field name is reserved on some database platforms warning
7 CommunicationLine IGNORE NaN NaN This field name is reserved on some database platforms warning
8 CommunicationLine THIS_ATTRIBUTE_IS_NECESSARY_TO_ NaN NaN This field is too long for some database platforms warning
9 CommunicationLine DOCUMENTEDBY_REQUIREMENTSPECIFI NaN NaN This field is too long for some database platforms warning
10 CommunicationLine TENSIONADJUSTMENTBYTEMPERATURE NaN NaN This field is too long for some database platforms warning
11 ElectricAssembly IGNORE NaN NaN This field name is reserved on some database platforms warning
12 ElectricDevice IGNORE NaN NaN This field name is reserved on some database platforms warning
13 ElectricDevice MEASUREMENTDISTANCEINTERVALCOOL NaN NaN This field is too long for some database platforms warning
14 ElectricDevice RATEDOPERATINGPOWERNEUTRALPOINT NaN NaN This field is too long for some database platforms warning
15 ElectricDevice CLUSTER NaN NaN This field name is reserved on some database platforms warning
16 ElectricDevice MAXCONTINUOUSOPERATINGVOLTAGEB1 NaN NaN This field is too long for some database platforms warning
17 ElectricDevice MAXCONTINUOUSOPERATINGVOLTAGEB2 NaN NaN This field is too long for some database platforms warning
18 ElectricDevice MAXCONTINUOUSOPERATINGVOLTAGEB3 NaN NaN This field is too long for some database platforms warning
19 ElectricDevice MAXCONTINUOUSOPERATINGVOLTAGEB4 NaN NaN This field is too long for some database platforms warning
20 ElectricEdgeObject IGNORE NaN NaN This field name is reserved on some database platforms warning
21 ElectricJunction IGNORE NaN NaN This field name is reserved on some database platforms warning
22 ElectricJunctionObject IGNORE NaN NaN This field name is reserved on some database platforms warning
23 ElectricLine IGNORE NaN NaN This field name is reserved on some database platforms warning
24 ElectricLine LENGTH NaN NaN This field name is reserved on some database platforms warning
25 ElectricLine DOCUMENTEDBY_REQUIREMENTSPECIFI NaN NaN This field is too long for some database platforms warning
26 ElectricLine TENSIONADJUSTMENTBYTEMPERATURE NaN NaN This field is too long for some database platforms warning
27 StructureBoundary IGNORE NaN NaN This field name is reserved on some database platforms warning
28 StructureBoundary LENGTH NaN NaN This field name is reserved on some database platforms warning
29 StructureBoundary CLUSTER NaN NaN This field name is reserved on some database platforms warning
30 StructureBoundarySF IGNORE NaN NaN This field name is reserved on some database platforms warning
31 StructureBoundarySF LENGTH NaN NaN This field name is reserved on some database platforms warning
32 StructureEdgeObject IGNORE NaN NaN This field name is reserved on some database platforms warning
33 StructureEdgeObject POSITIVESEQUENCESYSTEMRESISTANC NaN NaN This field is too long for some database platforms warning
34 StructureEdgeObject POSITIVESEQUENCESYSTEMREACTANCE NaN NaN This field is too long for some database platforms warning
35 StructureEdgeObject POSITIVESEQUENCESYSTEMCAPACITAN NaN NaN This field is too long for some database platforms warning
36 StructureEdgeObject MEASUREDPOSITIVESEQUENCESYSTEMR NaN NaN This field is too long for some database platforms warning
37 StructureJunction IGNORE NaN NaN This field name is reserved on some database platforms warning
38 StructureJunction LENGTH NaN NaN This field name is reserved on some database platforms warning
39 StructureJunctionObject IGNORE NaN NaN This field name is reserved on some database platforms warning
40 StructureJunctionSF IGNORE NaN NaN This field name is reserved on some database platforms warning
41 StructureJunctionSF THIS_ATTRIBUTE_IS_NECESSARY_TO_ NaN NaN This field is too long for some database platforms warning
42 StructureLine LENGTH NaN NaN This field name is reserved on some database platforms warning
43 StructureLine IGNORE NaN NaN This field name is reserved on some database platforms warning
44 StructureLine DOCUMENTEDBY_REQUIREMENTSPECIFI NaN NaN This field is too long for some database platforms warning
45 StructureLineSF LENGTH NaN NaN This field name is reserved on some database platforms warning
46 StructureLineSF IGNORE NaN NaN This field name is reserved on some database platforms warning
47 D_Rename rename_translation_fr 1846.0 37.0 Length of rename value must be <= 32 characters error
Delete that row(or shorten it), the translated value it too long.
need to remove at least 5 characters, the error says it is 37 characters long
Can you post a screen of this row in the rename table? That is the only row that is an error, the rest are just warnings.
It would row with OID of 1846
I've received new errors :
warning
46 StructureLineSF IGNORE None None This field name is reserved on some database platforms warning
47 AssetType_CommunicationEdgeObject_Telecom Cable None None 80|Câble en cuivre TC Domain code|description must be 80|Copper Cable TC error
48 AssetType_CommunicationEdgeObject_Telecom Cable None None 121|Câble à fibre optique TC Domain code|description must be 121|Fiber Optical Cable TC error
49 AssetType_CommunicationEdgeObject_Telecom Overhead Line None None 78|Câble aérien en cuivre TC Domain code|description must be 78|Copper Aerial Cable TC error
50 AssetType_CommunicationEdgeObject_Telecom Overhead Line None None 119|Câble aérien à fibre optique TC Domain code|description must be 119|Fiber Optical Aerial Cable TC error
51 AssetType_CommunicationJunctionObject_Telecom Conductor End None None 211|Junction de télécommunications Domain code|description must be 211|Telecom Joint error
52 AssetType_CommunicationJunction_Telecom Cable End None None 254|Pièce jointe TC Domain code|description must be 254|Attachment TC error
53 AssetType_CommunicationJunction_Telecom Cable End None None 269|Junction de télécommunications Domain code|description must be 269|Telecom Joint error
54 AssetType_CommunicationJunction_Telecom Conductor Loop None None 157|Boucle TC Domain code|description must be 157|Loop TC error
55 AssetType_CommunicationJunction_Telecom Overhead Line End None None 270|Lien Télécom Domain code|description must be 270|Telecom Link error
56 AssetType_CommunicationLine_Telecom Cable None None 72|Câble COAX TC Domain code|description must be 72|COAX Cable TC error
57 AssetType_CommunicationLine_Telecom Cable None None 79|Câble en cuivre TC Domain code|description must be 79|Copper Cable TC error
58 AssetType_CommunicationLine_Telecom Cable None None 120|Câble à fibre optique TC Domain code|description must be 120|Fiber Optical Cable TC error
59 AssetType_CommunicationLine_Telecom Overhead Line None None 71|COAX Câble aérien TC Domain code|description must be 71|COAX Aerial Cable TC error
60 AssetType_CommunicationLine_Telecom Overhead Line None None 77|Câble aérien en cuivre TC Domain code|description must be 77|Copper Aerial Cable TC error
61 AssetType_CommunicationLine_Telecom Overhead Line None None 118|Câble aérien à fibre optique TC Domain code|description must be 118|Fiber Optical Aerial Cable TC error
62 AssetType_ElectricAssembly_Low Voltage Distribution None None 18|Distribution CA BT Domain code|description must be 18|AC Distribution LV error
63 AssetType_ElectricAssembly_Low Voltage Distribution None None 93|Distribution CC BT Domain code|description must be 93|DC Distribution LV error
64 AssetType_ElectricDevice_Auxiliary None None 98|Détecteur Mètre Domain code|description must be 98|Detector Meter error
65 AssetType_ElectricDevice_Auxiliary None None 117|Indicateur de défaut Domain code|description must be 117|Fault Indicator error
66 AssetType_ElectricDevice_Auxiliary None None 159|Météo Mètre Domain code|description must be 159|Meteo Meter error
67 AssetType_ElectricDevice_Auxiliary None None 191|Capteur de mesure Domain code|description must be 191|Sensor Meter error
68 AssetType_ElectricDevice_Auxiliary None None 233|Piège à ondes Domain code|description must be 233|Wave Trap error
69 AssetType_ElectricDevice_Auxiliary None None 249|Protection CA HT Domain code|description must be 249|AC Protection HV error
70 AssetType_ElectricDevice_Auxiliary None None 256|Batterie Domain code|description must be 256|Battery error
71 AssetType_ElectricDevice_Auxiliary None None 258|Protection CC HT Domain code|description must be 258|DC Protection HV error
72 AssetType_ElectricDevice_Earthing Fault Compensator None None 166|Bobine Petersen Domain code|description must be 166|Petersen Coil error
73 AssetType_ElectricDevice_Earthing Switch None None 110|Sectionneur de terre Domain code|description must be 110|Earthing Switch error
74 AssetType_ElectricDevice_High Voltage Arrester None None 206|Parafoudre HT Domain code|description must be 206|Surge Arrester HV error
75 AssetType_ElectricDevice_High Voltage Arrester None None 266|Limiteur de tension de gaine Domain code|description must be 266|Sheath Voltage Limiter error
76 AssetType_ElectricDevice_High Voltage Control Unit None None 43|Unité de contrôle de baie HT Domain code|description must be 43|Bay Control Unit HV error
77 AssetType_ElectricDevice_High Voltage Control Unit None None 203|Unité de contrôle de sous-station HT Domain code|description must be 203|Substation Control Unit HV error
78 AssetType_ElectricDevice_High Voltage Generating Unit None None 46|Unité de Production de Biomasse HT Domain code|description must be 46|Biomass HV Generating Unit error
79 AssetType_ElectricDevice_High Voltage Generating Unit None None 70|Unité de production de charbon HT Domain code|description must be 70|Coal HV Generating Unit error
80 AssetType_ElectricDevice_High Voltage Generating Unit None None 111|Groupe électrogène HT de Secours Domain code|description must be 111|Emergency HV Generating Unit error
81 AssetType_ElectricDevice_High Voltage Generating Unit None None 123|Unité de Production Gaz HT Domain code|description must be 123|Gas HV Generating Unit error
82 AssetType_ElectricDevice_High Voltage Generating Unit None None 128|Unité de production géothermique HT Domain code|description must be 128|Geothermal HV Generating Unit error
83 AssetType_ElectricDevice_High Voltage Generating Unit None None 135|Unité de production hydroélectrique HT Domain code|description must be 135|Hydro HV Generating Unit error
84 AssetType_ElectricDevice_High Voltage Generating Unit None None 161|Unité de production nucléaire HT Domain code|description must be 161|Nuclear HV Generating Unit error
85 AssetType_ElectricDevice_High Voltage Generating Unit None None 188|Groupe électrogène HT à déphaseur rotatif Domain code|description must be 188|Rotating Phase Shifter HV Generating Unit error
86 AssetType_ElectricDevice_High Voltage Generating Unit None None 198|Unité de production solaire HT Domain code|description must be 198|Solar HV Generating Unit error
87 AssetType_ElectricDevice_High Voltage Generating Unit None None 214|Unité de production solaire thermique HT Domain code|description must be 214|Thermal Solar HV Generating Unit error
88 AssetType_ElectricDevice_High Voltage Generating Unit None None 231|Unité de production de déchets HT Domain code|description must be 231|Waste HV Generating Unit error
89 AssetType_ElectricDevice_High Voltage Generating Unit None None 234|Unité de production éolienne HT Domain code|description must be 234|Wind HV Generating Unit error
90 AssetType_ElectricDevice_High Voltage Instrument Transformer None None 73|Transformateur Combiné HT Domain code|description must be 73|Combined Transformer HV error
91 AssetType_ElectricDevice_High Voltage Instrument Transformer None None 84|Transformateur de courant HT Domain code|description must be 84|Current Transformer HV error
92 AssetType_ElectricDevice_High Voltage Instrument Transformer None None 228|Diviseur de tension HT Domain code|description must be 228|Voltage Divider HV error
93 AssetType_ElectricDevice_High Voltage Instrument Transformer None None 229|Transformateur de tension HT Domain code|description must be 229|Voltage Transformer HV error
94 AssetType_ElectricDevice_High Voltage Meter None None 176|Compteur de qualité HT Domain code|description must be 176|Quality Meter HV error
95 AssetType_ElectricDevice_High Voltage Meter None None 177|Compteur volumétrique HT Domain code|description must be 177|Quantity Meter HV error
96 AssetType_ElectricDevice_High Voltage Power Conversion None None 45|Convertisseur bidirectionnel HT Domain code|description must be 45|Bidirectional Converter HV error
97 AssetType_ElectricDevice_High Voltage Power Conversion None None 140|Onduleur HT Domain code|description must be 140|Inverter HV error
98 AssetType_ElectricDevice_High Voltage Power Conversion None None 179|Redresseur HT Domain code|description must be 179|Rectifier HV error
99 AssetType_ElectricDevice_High Voltage Power Factor Correcting None None 59|Condensateur HT Domain code|description must be 59|Capacitor HV error
If you could provide schema only asset package, we could troubleshoot easier. Run change asset package spatial reference and send us the output. [email protected]
