Error : rename during apply asset package _ UN Elec
2665
7
09-07-2023 02:25 PM
mazzouzi
I've created the French field in my d_rename table to translate my UN electric database, the problem is that when I try to apply the asset package, I get these errors, knowing that I've modified these fields one by one (I've emptied their translation fields and I've put the real bypass) but it doesn't work.
Have you ever had this kind of problem? Do you have any help on how it could be caused?
The asset package has the following errors (48/48):
                       Item                            Field     OID  Value                                                 Message    Level
0   CommunicationEdgeObject                           LENGTH     NaN    NaN  This field name is reserved on some database platforms  warning
1   CommunicationEdgeObject                           IGNORE     NaN    NaN  This field name is reserved on some database platforms  warning
2   CommunicationEdgeObject  THIS_ATTRIBUTE_IS_NECESSARY_TO_     NaN    NaN      This field is too long for some database platforms  warning
3   CommunicationEdgeObject  DOCUMENTEDBY_REQUIREMENTSPECIFI     NaN    NaN      This field is too long for some database platforms  warning
4   CommunicationEdgeObject   TENSIONADJUSTMENTBYTEMPERATURE     NaN    NaN      This field is too long for some database platforms  warning
5     CommunicationJunction                           IGNORE     NaN    NaN  This field name is reserved on some database platforms  warning
6         CommunicationLine                           LENGTH     NaN    NaN  This field name is reserved on some database platforms  warning
7         CommunicationLine                           IGNORE     NaN    NaN  This field name is reserved on some database platforms  warning
8         CommunicationLine  THIS_ATTRIBUTE_IS_NECESSARY_TO_     NaN    NaN      This field is too long for some database platforms  warning
9         CommunicationLine  DOCUMENTEDBY_REQUIREMENTSPECIFI     NaN    NaN      This field is too long for some database platforms  warning
10        CommunicationLine   TENSIONADJUSTMENTBYTEMPERATURE     NaN    NaN      This field is too long for some database platforms  warning
11         ElectricAssembly                           IGNORE     NaN    NaN  This field name is reserved on some database platforms  warning
12           ElectricDevice                           IGNORE     NaN    NaN  This field name is reserved on some database platforms  warning
13           ElectricDevice  MEASUREMENTDISTANCEINTERVALCOOL     NaN    NaN      This field is too long for some database platforms  warning
14           ElectricDevice  RATEDOPERATINGPOWERNEUTRALPOINT     NaN    NaN      This field is too long for some database platforms  warning
15           ElectricDevice                          CLUSTER     NaN    NaN  This field name is reserved on some database platforms  warning
16           ElectricDevice  MAXCONTINUOUSOPERATINGVOLTAGEB1     NaN    NaN      This field is too long for some database platforms  warning
17           ElectricDevice  MAXCONTINUOUSOPERATINGVOLTAGEB2     NaN    NaN      This field is too long for some database platforms  warning
18           ElectricDevice  MAXCONTINUOUSOPERATINGVOLTAGEB3     NaN    NaN      This field is too long for some database platforms  warning
19           ElectricDevice  MAXCONTINUOUSOPERATINGVOLTAGEB4     NaN    NaN      This field is too long for some database platforms  warning
20       ElectricEdgeObject                           IGNORE     NaN    NaN  This field name is reserved on some database platforms  warning
21         ElectricJunction                           IGNORE     NaN    NaN  This field name is reserved on some database platforms  warning
22   ElectricJunctionObject                           IGNORE     NaN    NaN  This field name is reserved on some database platforms  warning
23             ElectricLine                           IGNORE     NaN    NaN  This field name is reserved on some database platforms  warning
24             ElectricLine                           LENGTH     NaN    NaN  This field name is reserved on some database platforms  warning
25             ElectricLine  DOCUMENTEDBY_REQUIREMENTSPECIFI     NaN    NaN      This field is too long for some database platforms  warning
26             ElectricLine   TENSIONADJUSTMENTBYTEMPERATURE     NaN    NaN      This field is too long for some database platforms  warning
27        StructureBoundary                           IGNORE     NaN    NaN  This field name is reserved on some database platforms  warning
28        StructureBoundary                           LENGTH     NaN    NaN  This field name is reserved on some database platforms  warning
29        StructureBoundary                          CLUSTER     NaN    NaN  This field name is reserved on some database platforms  warning
30      StructureBoundarySF                           IGNORE     NaN    NaN  This field name is reserved on some database platforms  warning
31      StructureBoundarySF                           LENGTH     NaN    NaN  This field name is reserved on some database platforms  warning
32      StructureEdgeObject                           IGNORE     NaN    NaN  This field name is reserved on some database platforms  warning
33      StructureEdgeObject  POSITIVESEQUENCESYSTEMRESISTANC     NaN    NaN      This field is too long for some database platforms  warning
34      StructureEdgeObject  POSITIVESEQUENCESYSTEMREACTANCE     NaN    NaN      This field is too long for some database platforms  warning
35      StructureEdgeObject  POSITIVESEQUENCESYSTEMCAPACITAN     NaN    NaN      This field is too long for some database platforms  warning
36      StructureEdgeObject  MEASUREDPOSITIVESEQUENCESYSTEMR     NaN    NaN      This field is too long for some database platforms  warning
37        StructureJunction                           IGNORE     NaN    NaN  This field name is reserved on some database platforms  warning
38        StructureJunction                           LENGTH     NaN    NaN  This field name is reserved on some database platforms  warning
39  StructureJunctionObject                           IGNORE     NaN    NaN  This field name is reserved on some database platforms  warning
40      StructureJunctionSF                           IGNORE     NaN    NaN  This field name is reserved on some database platforms  warning
41      StructureJunctionSF  THIS_ATTRIBUTE_IS_NECESSARY_TO_     NaN    NaN      This field is too long for some database platforms  warning
42            StructureLine                           LENGTH     NaN    NaN  This field name is reserved on some database platforms  warning
43            StructureLine                           IGNORE     NaN    NaN  This field name is reserved on some database platforms  warning
44            StructureLine  DOCUMENTEDBY_REQUIREMENTSPECIFI     NaN    NaN      This field is too long for some database platforms  warning
45          StructureLineSF                           LENGTH     NaN    NaN  This field name is reserved on some database platforms  warning
46          StructureLineSF                           IGNORE     NaN    NaN  This field name is reserved on some database platforms  warning
47                 D_Rename            rename_translation_fr  1846.0   37.0         Length of rename value must be <= 32 characters    error
2 Solutions
MikeMillerGIS
Esri Frequent Contributor
Delete that row(or shorten it), the translated value it too long.
MikeMillerGIS
need to remove at least 5 characters, the error says it is 37 characters long
MikeMillerGIS
Can you post a screen of this row in the rename table?  That is the only row that is an error, the rest are just warnings.
MikeMillerGIS
It would row with OID of 1846
mazzouzi
MikeMillerGIS
MikeMillerGIS
mazzouzi
I've received new errors :
warning
46                                                StructureLineSF                           IGNORE  None                                           None                         This field name is reserved on some database platforms  warning
47                AssetType_CommunicationEdgeObject_Telecom Cable                             None  None                          80|Câble en cuivre TC                             Domain code|description must be 80|Copper Cable TC    error
48                AssetType_CommunicationEdgeObject_Telecom Cable                             None  None                   121|Câble à fibre optique TC                     Domain code|description must be 121|Fiber Optical Cable TC    error
49        AssetType_CommunicationEdgeObject_Telecom Overhead Line                             None  None                   78|Câble aérien en cuivre TC                      Domain code|description must be 78|Copper Aerial Cable TC    error
50        AssetType_CommunicationEdgeObject_Telecom Overhead Line                             None  None            119|Câble aérien à fibre optique TC              Domain code|description must be 119|Fiber Optical Aerial Cable TC    error
51    AssetType_CommunicationJunctionObject_Telecom Conductor End                             None  None             211|Junction de télécommunications                              Domain code|description must be 211|Telecom Joint    error
52              AssetType_CommunicationJunction_Telecom Cable End                             None  None                            254|Pièce jointe TC                              Domain code|description must be 254|Attachment TC    error
53              AssetType_CommunicationJunction_Telecom Cable End                             None  None             269|Junction de télécommunications                              Domain code|description must be 269|Telecom Joint    error
54         AssetType_CommunicationJunction_Telecom Conductor Loop                             None  None                                  157|Boucle TC                                    Domain code|description must be 157|Loop TC    error
55      AssetType_CommunicationJunction_Telecom Overhead Line End                             None  None                               270|Lien Télécom                               Domain code|description must be 270|Telecom Link    error
56                      AssetType_CommunicationLine_Telecom Cable                             None  None                               72|Câble COAX TC                               Domain code|description must be 72|COAX Cable TC    error
57                      AssetType_CommunicationLine_Telecom Cable                             None  None                          79|Câble en cuivre TC                             Domain code|description must be 79|Copper Cable TC    error
58                      AssetType_CommunicationLine_Telecom Cable                             None  None                   120|Câble à fibre optique TC                     Domain code|description must be 120|Fiber Optical Cable TC    error
59              AssetType_CommunicationLine_Telecom Overhead Line                             None  None                        71|COAX Câble aérien TC                        Domain code|description must be 71|COAX Aerial Cable TC    error
60              AssetType_CommunicationLine_Telecom Overhead Line                             None  None                   77|Câble aérien en cuivre TC                      Domain code|description must be 77|Copper Aerial Cable TC    error
61              AssetType_CommunicationLine_Telecom Overhead Line                             None  None            118|Câble aérien à fibre optique TC              Domain code|description must be 118|Fiber Optical Aerial Cable TC    error
62            AssetType_ElectricAssembly_Low Voltage Distribution                             None  None                          18|Distribution CA BT                          Domain code|description must be 18|AC Distribution LV    error
63            AssetType_ElectricAssembly_Low Voltage Distribution                             None  None                          93|Distribution CC BT                          Domain code|description must be 93|DC Distribution LV    error
64                             AssetType_ElectricDevice_Auxiliary                             None  None                             98|Détecteur Mètre                              Domain code|description must be 98|Detector Meter    error
65                             AssetType_ElectricDevice_Auxiliary                             None  None                       117|Indicateur de défaut                            Domain code|description must be 117|Fault Indicator    error
66                             AssetType_ElectricDevice_Auxiliary                             None  None                                159|Météo Mètre                                Domain code|description must be 159|Meteo Meter    error
67                             AssetType_ElectricDevice_Auxiliary                             None  None                          191|Capteur de mesure                               Domain code|description must be 191|Sensor Meter    error
68                             AssetType_ElectricDevice_Auxiliary                             None  None                              233|Piège à ondes                                  Domain code|description must be 233|Wave Trap    error
69                             AssetType_ElectricDevice_Auxiliary                             None  None                           249|Protection CA HT                           Domain code|description must be 249|AC Protection HV    error
70                             AssetType_ElectricDevice_Auxiliary                             None  None                                   256|Batterie                                    Domain code|description must be 256|Battery    error
71                             AssetType_ElectricDevice_Auxiliary                             None  None                           258|Protection CC HT                           Domain code|description must be 258|DC Protection HV    error
72            AssetType_ElectricDevice_Earthing Fault Compensator                             None  None                            166|Bobine Petersen                              Domain code|description must be 166|Petersen Coil    error
73                       AssetType_ElectricDevice_Earthing Switch                             None  None                       110|Sectionneur de terre                            Domain code|description must be 110|Earthing Switch    error
74                 AssetType_ElectricDevice_High Voltage Arrester                             None  None                              206|Parafoudre HT                          Domain code|description must be 206|Surge Arrester HV    error
75                 AssetType_ElectricDevice_High Voltage Arrester                             None  None               266|Limiteur de tension de gaine                     Domain code|description must be 266|Sheath Voltage Limiter    error
76             AssetType_ElectricDevice_High Voltage Control Unit                             None  None                43|Unité de contrôle de baie HT                         Domain code|description must be 43|Bay Control Unit HV    error
77             AssetType_ElectricDevice_High Voltage Control Unit                             None  None       203|Unité de contrôle de sous-station HT                 Domain code|description must be 203|Substation Control Unit HV    error
78          AssetType_ElectricDevice_High Voltage Generating Unit                             None  None          46|Unité de Production de Biomasse HT                  Domain code|description must be 46|Biomass HV Generating Unit    error
79          AssetType_ElectricDevice_High Voltage Generating Unit                             None  None           70|Unité de production de charbon HT                     Domain code|description must be 70|Coal HV Generating Unit    error
80          AssetType_ElectricDevice_High Voltage Generating Unit                             None  None           111|Groupe électrogène HT de Secours               Domain code|description must be 111|Emergency HV Generating Unit    error
81          AssetType_ElectricDevice_High Voltage Generating Unit                             None  None                 123|Unité de Production Gaz HT                     Domain code|description must be 123|Gas HV Generating Unit    error
82          AssetType_ElectricDevice_High Voltage Generating Unit                             None  None        128|Unité de production géothermique HT              Domain code|description must be 128|Geothermal HV Generating Unit    error
83          AssetType_ElectricDevice_High Voltage Generating Unit                             None  None     135|Unité de production hydroélectrique HT                   Domain code|description must be 135|Hydro HV Generating Unit    error
84          AssetType_ElectricDevice_High Voltage Generating Unit                             None  None           161|Unité de production nucléaire HT                 Domain code|description must be 161|Nuclear HV Generating Unit    error
85          AssetType_ElectricDevice_High Voltage Generating Unit                             None  None  188|Groupe électrogène HT à déphaseur rotatif  Domain code|description must be 188|Rotating Phase Shifter HV Generating Unit    error
86          AssetType_ElectricDevice_High Voltage Generating Unit                             None  None             198|Unité de production solaire HT                   Domain code|description must be 198|Solar HV Generating Unit    error
87          AssetType_ElectricDevice_High Voltage Generating Unit                             None  None   214|Unité de production solaire thermique HT           Domain code|description must be 214|Thermal Solar HV Generating Unit    error
88          AssetType_ElectricDevice_High Voltage Generating Unit                             None  None          231|Unité de production de déchets HT                   Domain code|description must be 231|Waste HV Generating Unit    error
89          AssetType_ElectricDevice_High Voltage Generating Unit                             None  None            234|Unité de production éolienne HT                    Domain code|description must be 234|Wind HV Generating Unit    error
90   AssetType_ElectricDevice_High Voltage Instrument Transformer                             None  None                   73|Transformateur Combiné HT                     Domain code|description must be 73|Combined Transformer HV    error
91   AssetType_ElectricDevice_High Voltage Instrument Transformer                             None  None                84|Transformateur de courant HT                      Domain code|description must be 84|Current Transformer HV    error
92   AssetType_ElectricDevice_High Voltage Instrument Transformer                             None  None                     228|Diviseur de tension HT                         Domain code|description must be 228|Voltage Divider HV    error
93   AssetType_ElectricDevice_High Voltage Instrument Transformer                             None  None               229|Transformateur de tension HT                     Domain code|description must be 229|Voltage Transformer HV    error
94                    AssetType_ElectricDevice_High Voltage Meter                             None  None                     176|Compteur de qualité HT                           Domain code|description must be 176|Quality Meter HV    error
95                    AssetType_ElectricDevice_High Voltage Meter                             None  None                   177|Compteur volumétrique HT                          Domain code|description must be 177|Quantity Meter HV    error
96         AssetType_ElectricDevice_High Voltage Power Conversion                             None  None             45|Convertisseur bidirectionnel HT                  Domain code|description must be 45|Bidirectional Converter HV    error
97         AssetType_ElectricDevice_High Voltage Power Conversion                             None  None                                140|Onduleur HT                                Domain code|description must be 140|Inverter HV    error
98         AssetType_ElectricDevice_High Voltage Power Conversion                             None  None                              179|Redresseur HT                               Domain code|description must be 179|Rectifier HV    error
99  AssetType_ElectricDevice_High Voltage Power Factor Correcting               None  None                             59|Condensateur HT                                Domain code|description must be 59|Capacitor HV    error
MikeMillerGIS
If you could provide schema only asset package, we could troubleshoot easier.  Run change asset package spatial reference and send us the output.  [email protected]
