Delete Enteprise DB error
2083
04-20-2020 09:14 AM
FilipKuzman
Hi everyone,
I am using MS SQL 17 and ArcGIS Pro 2.5. What I want to do is to publish a utility network from a file geodatabase. So I  started with an attempt to copy/paste my utility network to Enterprise geodatabase. However, that was not possible because I would non stop get an error 000260. I played with some script to fix that, it didn't work. My next idea was to export an asset package from a file geodatabase and apply it to Enterprise. I have created the same service area and Utility network in Enterprise gdb and applied the asset package. That worked perfectly.
However, after that, I deleted/drop the database from the SQL server(what I have read it is the recommended way to delete Gdb by some users in Pro) because of some issues with versioning and tried to repeat previous steps. And now I am experiencing several errors. Pro would create the UN on Enterprise gdb without any errors but every time I would try to add that newly created UN layer to the map or try to see the properties of the UN layer ArcGIS Pro would crash. If I try to apply an asset package to it, it would say that the only data owner has permission to do that. However, I am logged with the right portal account which is the data owner. I believe it can not read the UN layer properly because is broken.
Now I have a question, what would cause this? At first, I didn't have any problems. I deleted DB from MS SQL studio but left the SDE table, so I am very suspicious that I haven't deleted something right. And I don't know if it might be important it is SDE owned schema gdb. Or that on the portal I am still assigned as Utility network owner of the previous network?
I tried to create gdb with a new database from SQL, new users. Nope. Same error.
Thank you
George_Thompson
Esri Notable Contributor
how did you delete the database but leave the SDE tables?
Did you delete all the tables that were like this; "dataowner.tablename" in SSMS?
Have you attempted to create a brand new SQL Server Enterprise Geodatabase using the Create Enterprise Geodatabase GP tool?
I think that I am a little confused on the steps and exact processes you have completed in relation to the DB "drop/delete".
--- George T.
FilipKuzman
Hi George,
firstly, thank you for the answer!
I believe it is confusing.
I have deleted the database in which I stored my Geodatabase. So the DB described in step 5 section "Run the Create Enterprise Geodatabase tool" at this link Create a geodatabase in SQL Server—Manage geodatabases in SQL Server | Documentation. I think you understood right. And yes, for both times I was using the Create Enterprise Geodatabase GP tool. With two different databases previously mentioned for storing Geodatabase(I have deleted first one)
FilipKuzman
Oh and I forgot to say that regarding SDE tables, I meant actually on sde database. I used the wrong word.
George_Thompson
Ok, if you created a new SQL Enterprise Geodatabase then you should have no issues.
For these issues, I would recommend that contact Esri Technical support and open a case with a Geodatabase analyst to review the behavior.
It may be too difficult to troubleshoot via the forum.
--- George T.
