Updating Survey123 Connect
1401
01-08-2020 12:27 PM
JayH
Hello all,
This may be a silly question - Should I uninstall the existing Survey123 Connect before installing the new version? I kind of expected something similar to Pro - updating will be done while preserving all exciting data and folder structures, but I got an error while trying to overwrite the existing Survey123 folder.
Cheers,
ChelseaRozek
MVP Regular Contributor
Yup, you have to uninstall Connect before installing the newer version.
When uninstalling, it will say this:
My surveys are stored elsewhere (which I believe is the default), so that's fine. You can double check where yours are saved by clicking on a survey's 3 dot menu in Connect and then choosing Show folder and seeing where that folder lives.
JayH
Hi Chelsea, I could install the new version, and confirmed that all my old surveys are still there under user folder. Thanks for sharing your experience.
Cheers,
DougBrowning
MVP Esteemed Contributor
On mine I can install it but am blocked from Uninstall.  So I just add a 36, 37, etc to the end of the install path.
Seems to work fine.
by Anonymous User
Not applicable
@Anonymous User
